Salta al contenuto principale
Nikon CoolPix S5 LCD Screen Replacement
Josh Miller
Josh Miller e 9 altri collaboratori
Ultimo aggiornamento il 29 dic 2022
10 - 15 minuti
Moderato
Immagini Non Adeguate
Introduzione
Vai al passo 1
This guide illustrates how to remove and install an LCD screen into the camera casing. These instructions are useful if the camera screen becomes damaged or no longer functions properly due to overuse. A Phillips-head screwdriver is necessary to complete this installation.
Cosa ti serve
Strumenti
  1. Nikon CoolPix S5 LCD Screen Replacement, Back Cover: passo 1, immagine 1 di 1
    • Remove the wristlet by untying the strap.
  2. Nikon CoolPix S5 LCD Screen Replacement: passo 2, immagine 1 di 1
    • Open the SD/Battery cover.
  3. Nikon CoolPix S5 LCD Screen Replacement: passo 3, immagine 1 di 2 Nikon CoolPix S5 LCD Screen Replacement: passo 3, immagine 2 di 2
    • Remove the four screws adjacent to the SD/battery opening using a Phillips #00 screwdriver.
  4. Nikon CoolPix S5 LCD Screen Replacement: passo 4, immagine 1 di 2 Nikon CoolPix S5 LCD Screen Replacement: passo 4, immagine 2 di 2
    • Remove the side paneling of the camera by prying it off with your hands.
  5. Nikon CoolPix S5 LCD Screen Replacement: passo 5, immagine 1 di 2 Nikon CoolPix S5 LCD Screen Replacement: passo 5, immagine 2 di 2
    • Start on the wristlet side of the camera and use the #00 Phillips screwdriver to remove the two screws that hold the backplate in place.
    • Repeat the removal of the two screws on the other side of the camera.
  6. Nikon CoolPix S5 LCD Screen Replacement: passo 6, immagine 1 di 2 Nikon CoolPix S5 LCD Screen Replacement: passo 6, immagine 2 di 2
    • Separate the back faceplate from the rest of the camera.
  7. Nikon CoolPix S5 LCD Screen Replacement, LCD Screen: passo 7, immagine 1 di 1
    • Gently lift the LCD screen.
    • Disconnect the ribbon cables from the ports.
  8. Nikon CoolPix S5 LCD Screen Replacement: passo 8, immagine 1 di 1
    • Remove the LCD screen from the camera.
Conclusione
Josh Miller
Membro da: 03/11/13
87 Reputazione
3 Guide realizzate
Clemson, Team 12-5, Benson Spring 2013 Membro di Clemson, Team 12-5, Benson Spring 2013
CLEM-BENSON-S13S12G5
4 Membri
14 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 15
Tutti i Tempi: 985
