Salta al contenuto principale
Nikon CoolPix S5 Battery Replacement
Cosa ti serve
  1. Nikon CoolPix S5 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Using the thumb, firmly push the SD/Battery cover in the middle and then in the direction of the arrow on the SD/Battery cover.
    • This will cause the SD/Battery cover to pop open.
  2. Nikon CoolPix S5 Battery Replacement: passo 2, immagine 1 di 1
    • Press orange clip to eject battery (battery not shown).
  3. Nikon CoolPix S5 Battery Replacement: passo 3, immagine 1 di 1
    • While cupping hand under the bottom of the SD/Battery slot, turn the camera upright.
    • This will cause the battery to fall into the hand (battery not shown).
  4. Nikon CoolPix S5 Battery Replacement: passo 4, immagine 1 di 1
    • Following the positive and negative placement signs, slide the new battery into the battery slot (battery not shown).
  5. Nikon CoolPix S5 Battery Replacement: passo 5, immagine 1 di 1
    • Slide the SD/Battery cover in the reverse direction of the arrow on the SD/Battery cover until it clicks into place.
Conclusione
Altre 4 persone hanno completato questa guida.
Clemson, Team 12-5, Benson Spring 2013 Membro di Clemson, Team 12-5, Benson Spring 2013
CLEM-BENSON-S13S12G5
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 28
Tutti i Tempi: 789
