Salta al contenuto principale
Nikon COOLPIX S610c Rear Casing Replacement
Cosa ti serve
  1. Nikon COOLPIX S610c Rear Casing Replacement, Battery: passo 1, immagine 1 di 1
    • On the bottom right of the camera, locate the battery flap switch.
  2. Nikon COOLPIX S610c Rear Casing Replacement: passo 2, immagine 1 di 1
    • Move this switch to the right so the battery flap can flip open.
  3. Nikon COOLPIX S610c Rear Casing Replacement: passo 3, immagine 1 di 1
    • Slide the orange switch to the right as shown. Now the battery can be pulled out. Reverse these steps to re-install.
  4. Nikon COOLPIX S610c Rear Casing Replacement, Rear Casing: passo 4, immagine 1 di 1
    • Remove the three 3x3mm screws attached to the rear casing.
  5. Nikon COOLPIX S610c Rear Casing Replacement: passo 5, immagine 1 di 1
    • The panel can be identified by the wifi logo on its upper half on the camera's side.
    • Remove the 5x3mm screw holding down the panel on the side closest to the lens.
  6. Nikon COOLPIX S610c Rear Casing Replacement: passo 6, immagine 1 di 1
    • Pry the panel off from the bottom using your fingernail.
  7. Nikon COOLPIX S610c Rear Casing Replacement: passo 7, immagine 1 di 1
    • Remove the 3x2mm screw underneath the panel near the top of the camera.
  8. Nikon COOLPIX S610c Rear Casing Replacement: passo 8, immagine 1 di 2 Nikon COOLPIX S610c Rear Casing Replacement: passo 8, immagine 2 di 2
    • Remove the 4x3mm on the opposite side near the selector wheel.
    • Remove the 2x2mm and 3x2mm screws underneath the a/v flap.
  9. Nikon COOLPIX S610c Rear Casing Replacement: passo 9, immagine 1 di 2 Nikon COOLPIX S610c Rear Casing Replacement: passo 9, immagine 2 di 2
    • Pry the back panel away from the body of the camera, using the space you just opened up.
    • Be careful not to damage the ribbon cable on the opposite end of the camera.
    • A small piece of the frame of the camera may fall off, but it can be easily put back into place during reassembly.
  10. Nikon COOLPIX S610c Rear Casing Replacement: passo 10, immagine 1 di 2 Nikon COOLPIX S610c Rear Casing Replacement: passo 10, immagine 2 di 2
    • Pry up the plastic ribbon connectors on the body of the camera to release the ribbon cables.
    • The center connector is detached by flipping the black latch up and away from the center of the camera.
    • The smaller connector is detached by flipping the tan latch up and away from the edge of the camera.
Conclusione
Kevin Backers
Membro da: 01/26/12
301 Reputazione
4 Guide realizzate
Cal Poly, Team 9-5, Regan Winter 2012 Membro di Cal Poly, Team 9-5, Regan Winter 2012
CPSU-REGAN-W12S9G5
5 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 912
