Salta al contenuto principale
Nikon COOLPIX S610c Front Casing Replacement
Cosa ti serve
  1. Nikon COOLPIX S610c Front Casing Replacement, Battery: passo 1, immagine 1 di 1
    • On the bottom right of the camera, locate the battery flap switch.
  2. Nikon COOLPIX S610c Front Casing Replacement: passo 2, immagine 1 di 1
    • Move this switch to the right so the battery flap can flip open.
  3. Nikon COOLPIX S610c Front Casing Replacement: passo 3, immagine 1 di 1
    • Slide the orange switch to the right as shown. Now the battery can be pulled out. Reverse these steps to re-install.
  4. Nikon COOLPIX S610c Front Casing Replacement, Rear Casing: passo 4, immagine 1 di 1
    • Remove the three 3x3mm screws attached to the rear casing.
  5. Nikon COOLPIX S610c Front Casing Replacement: passo 5, immagine 1 di 1
    • The panel can be identified by the wifi logo on its upper half on the camera's side.
    • Remove the 5x3mm screw holding down the panel on the side closest to the lens.
  6. Nikon COOLPIX S610c Front Casing Replacement: passo 6, immagine 1 di 1
    • Pry the panel off from the bottom using your fingernail.
  7. Nikon COOLPIX S610c Front Casing Replacement: passo 7, immagine 1 di 1
    • Remove the 3x2mm screw underneath the panel near the top of the camera.
  8. Nikon COOLPIX S610c Front Casing Replacement: passo 8, immagine 1 di 2 Nikon COOLPIX S610c Front Casing Replacement: passo 8, immagine 2 di 2
    • Remove the 4x3mm on the opposite side near the selector wheel.
    • Remove the 2x2mm and 3x2mm screws underneath the a/v flap.
  9. Nikon COOLPIX S610c Front Casing Replacement: passo 9, immagine 1 di 2 Nikon COOLPIX S610c Front Casing Replacement: passo 9, immagine 2 di 2
    • Pry the back panel away from the body of the camera, using the space you just opened up.
    • Be careful not to damage the ribbon cable on the opposite end of the camera.
    • A small piece of the frame of the camera may fall off, but it can be easily put back into place during reassembly.
  10. Nikon COOLPIX S610c Front Casing Replacement: passo 10, immagine 1 di 2 Nikon COOLPIX S610c Front Casing Replacement: passo 10, immagine 2 di 2
    • Pry up the plastic ribbon connectors on the body of the camera to release the ribbon cables.
    • The center connector is detached by flipping the black latch up and away from the center of the camera.
    • The smaller connector is detached by flipping the tan latch up and away from the edge of the camera.
  11. Nikon COOLPIX S610c Front Casing Replacement, Front Casing: passo 11, immagine 1 di 1
    • Remove the three 3x3mm screws that attach the front casing to the bottom.
  12. Nikon COOLPIX S610c Front Casing Replacement: passo 12, immagine 1 di 1
    • Remove the two 3x2 screws and two 3.5x2.5 screws attaching the rear panel to the motherboard.
  13. Nikon COOLPIX S610c Front Casing Replacement: passo 13, immagine 1 di 2 Nikon COOLPIX S610c Front Casing Replacement: passo 13, immagine 2 di 2
    • Lift the back panel off the motherboard.
    • Be careful not to damage the ribbon cable that attaches the mother board to the rear panel.
  14. Nikon COOLPIX S610c Front Casing Replacement: passo 14, immagine 1 di 2 Nikon COOLPIX S610c Front Casing Replacement: passo 14, immagine 2 di 2
    • Detach the ribbon cable from the motherboard by flipping up the latch on the ribbon connector.
    • Note that the white ribbon connector latch flips away from the ribbon cable.
  15. Nikon COOLPIX S610c Front Casing Replacement: passo 15, immagine 1 di 2 Nikon COOLPIX S610c Front Casing Replacement: passo 15, immagine 2 di 2
    • Remove the final 4x3mm screw at the top of the camera near the lens.
  16. Nikon COOLPIX S610c Front Casing Replacement: passo 16, immagine 1 di 2 Nikon COOLPIX S610c Front Casing Replacement: passo 16, immagine 2 di 2
    • Pry the front casing away from the body of the camera.
    • Be careful not to damage the wires that attach the front panel to the motherboard.
    • Short the leads on the capacitor near the flash to avoid a nasty shock when separating the casing from the body.
  17. Nikon COOLPIX S610c Front Casing Replacement: passo 17, immagine 1 di 1
    • Unscrew the three 3x2mm screws that attach the cables to the front casing.
Conclusione
Bryan Bell
Membro da: 01/26/12
28 Reputazione
1 Guida realizzata
Cal Poly, Team 9-5, Regan Winter 2012 Membro di Cal Poly, Team 9-5, Regan Winter 2012
CPSU-REGAN-W12S9G5
5 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,158
