Salta al contenuto principale
Nikon COOLPIX S3600 SD Card Replacement
  1. Nikon COOLPIX S3600 SD Card Replacement, SD Card: passo 1, immagine 1 di 2 Nikon COOLPIX S3600 SD Card Replacement, SD Card: passo 1, immagine 2 di 2
    • Push latch downwards to open the battery hatch located on the bottom right.
    • Memory card is located above the battery compartment.
  2. Nikon COOLPIX S3600 SD Card Replacement: passo 2, immagine 1 di 3 Nikon COOLPIX S3600 SD Card Replacement: passo 2, immagine 2 di 3 Nikon COOLPIX S3600 SD Card Replacement: passo 2, immagine 3 di 3
    • Push in the memory card until you can't push it in any more and release.
    • Memory card should be slightly popped up.
    • Now you can carefully remove the memory card.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 85
Tutti i Tempi: 3,151
