Salta al contenuto principale
Nikon COOLPIX S3600 Battery Cover Replacement
Cosa ti serve
  1. Nikon COOLPIX S3600 Battery Cover Replacement, Battery Cover: passo 1, immagine 1 di 2 Nikon COOLPIX S3600 Battery Cover Replacement, Battery Cover: passo 1, immagine 2 di 2
    • Locate the battery cover on the right side of the bottom of the camera.
    • To open the cover, gently slide it in the direction indicated by the arrow.
  2. Nikon COOLPIX S3600 Battery Cover Replacement: passo 2, immagine 1 di 3 Nikon COOLPIX S3600 Battery Cover Replacement: passo 2, immagine 2 di 3 Nikon COOLPIX S3600 Battery Cover Replacement: passo 2, immagine 3 di 3
    • Once the battery cover door is open, insert the pointed end of a spudger underneath the metal door hinge.
    • Gently twist the spudger; the battery door cover should pop off.
    • Completely remove the cover from the hinge.
Conclusione
To reattach the battery cover door, align the metal hinge with the plastic cover and press the plastic cover downward until it snaps into place.
Kim Maxson
Membro da: 03/18/15
101 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 415
