Salta al contenuto principale
Nikon COOLPIX P2 LCD Screen Replacement
Cosa ti serve
  1. Nikon COOLPIX P2 LCD Screen Replacement, Case: passo 1, immagine 1 di 1
    • Remove the screw located near the speaker port using a Phillips 00 screwdriver.
  2. Nikon COOLPIX P2 LCD Screen Replacement: passo 2, immagine 1 di 1
    • Turn camera upside down so that the battery compartment is facing you.
    • Remove all four screws from the bottom of the camera with a Phillips 00 screwdriver.
  3. Nikon COOLPIX P2 LCD Screen Replacement: passo 3, immagine 1 di 1
    • Rotate the camera to the opposite side where the A/V outlet is located.
    • Unscrew and remove all four screws with a Phillips 00 screwdriver.
  4. Nikon COOLPIX P2 LCD Screen Replacement: passo 4, immagine 1 di 1
    • Turn the camera so that the Wi-Fi adapter is facing you.
  5. Nikon COOLPIX P2 LCD Screen Replacement: passo 5, immagine 1 di 3 Nikon COOLPIX P2 LCD Screen Replacement: passo 5, immagine 2 di 3 Nikon COOLPIX P2 LCD Screen Replacement: passo 5, immagine 3 di 3
    • Using a plastic opening tool, pry the front casing of the camera.
    • Continue this motion all around the front casing of the camera.
    • Gently pull apart the front casing from the rest of the camera.
  6. Nikon COOLPIX P2 LCD Screen Replacement: passo 6, immagine 1 di 1
    • Using the plastic opening tool pry the back casing of the camera.
  7. Nikon COOLPIX P2 LCD Screen Replacement: passo 7, immagine 1 di 1
    • Orange ribbon is fragile
    • Carefully pull apart the back casing of the camera from the front of the camera without tearing the orange ribbon.
  8. Nikon COOLPIX P2 LCD Screen Replacement: passo 8, immagine 1 di 2 Nikon COOLPIX P2 LCD Screen Replacement: passo 8, immagine 2 di 2
    • Pull down the on the black latch to carefully separate the orange ribbon from the motherboard.
    • Pull apart the orange ribbon and front casing from the rest of the camera.
  9. Nikon COOLPIX P2 LCD Screen Replacement, LCD Screen: passo 9, immagine 1 di 2 Nikon COOLPIX P2 LCD Screen Replacement, LCD Screen: passo 9, immagine 2 di 2
    • Use plastic opening tool to carefully pry the LCD Screen from the camera.
  10. Nikon COOLPIX P2 LCD Screen Replacement: passo 10, immagine 1 di 2 Nikon COOLPIX P2 LCD Screen Replacement: passo 10, immagine 2 di 2
    • Gently pull the ribbon cable down to release the latch, then pull up to remove it from the motherboard.
  11. Nikon COOLPIX P2 LCD Screen Replacement: passo 11, immagine 1 di 1
Conclusione
Joshua Avery
Membro da: 01/23/12
31 Reputazione
3 Guide realizzate
Cal Poly, Team 3-28, Amido Winter 2012 Membro di Cal Poly, Team 3-28, Amido Winter 2012
CPSU-AMIDO-W12S3G28
4 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,264
