Salta al contenuto principale
Nikon 1 J3 LCD Screen Replacement
Cosa ti serve
  1. Nikon 1 J3 LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 2 Nikon 1 J3 LCD Screen Replacement, LCD Screen: passo 1, immagine 2 di 2
    • Using a Phillips #000 screwdriver, remove the three bottom screws connected to the back plate on the bottom of the device.
    • Remove the screws under the flaps covering the HDMI and mini USB ports.
    Achtung bei der Anleitung fehlt das entfernen von 2 Schrauben. Dann kann man die Plastikplatte ohne biegen und brechen abnehmen und zwar unter der Klebeplatte auf der Seite nach der man aufklappt. (ist festgeklebt)
    Jan Birthelmer - Replica
    Tuto misses 2 screws hidden behind a small plastic cover on the button side of the camera.
    Once these 2 screws are removed, the entire bezel removes easily.
    Pierre-Henri Francois - Replica
  2. Nikon 1 J3 LCD Screen Replacement: passo 2, immagine 1 di 1
    • Carefully pry back the back plate.
    • The plastic of the back plate may crack.
  3. Nikon 1 J3 LCD Screen Replacement: passo 3, immagine 1 di 1
    • Lift up the screen, and use a Phillips #000 screwdriver to remove the (6) six screws holding down the underlying metal plate.
  4. Nikon 1 J3 LCD Screen Replacement: passo 4, immagine 1 di 1
    • Pull back the black switch holding the orange screen ribbon in place, and remove the screen.
Conclusione
Austin Lackey
Membro da: 09/26/17
479 Reputazione
4 Guide realizzate
USF Tampa, Team S11-G4, Passmore Fall 2017 Membro di USF Tampa, Team S11-G4, Passmore Fall 2017
USFT-PASSMORE-F17S11G4
3 Membri
4 Guide realizzate
3 Commenti
Hey, I’m having trouble removing the back plate on step 2. It seems to be stuck on the side opposite the HDMI and USB ports, any tips for removing it? Thanks!
johnjames460 - Replica
Step 1 seems to mis removal of 2 screws. Check tutorial below:
https://www.lifepixel.com/tutorials/infr...
Marcel Rossewij - Replica
I am about to replace the lcd screen on my J4 - is the method the same as for the J3? And do I need any adhesive?
Nicholas Glover - 2nd April 2023
Nicholas Glover - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,173
