Salta al contenuto principale
Nikon 1 AW 1 O-Ring Replacement
Cosa ti serve
  1. Nikon 1 AW 1 O-Ring Replacement, O-Ring: passo 1, immagine 1 di 2 Nikon 1 AW 1 O-Ring Replacement, O-Ring: passo 1, immagine 2 di 2
    • Press and hold the lens release button, twist the lens in a clockwise motion, then pull it off of the camera.
  2. Nikon 1 AW 1 O-Ring Replacement: passo 2, immagine 1 di 3 Nikon 1 AW 1 O-Ring Replacement: passo 2, immagine 2 di 3 Nikon 1 AW 1 O-Ring Replacement: passo 2, immagine 3 di 3
    • Squeeze the O-ring under the lens support to push out the O-ring. Use a plastic opening tool to get under the O-ring, and slowly work around the metal lens support to pull the O-ring completely out.
Conclusione
USF Tampa, Team 3-4, Sullivan Fall 2016 Membro di USF Tampa, Team 3-4, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G4
4 Membri
6 Guide realizzate
1Commento della guida
Hello, it appears that Nikon has discontinued the Nikon 1 AW1 WP-O2000 O-ring. Can anyone suggest a non-OEM alternatives?
Justin Wade Thornton - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 16
Tutti i Tempi: 859
