Salta al contenuto principale
Nike SportWatch GPS LCD Screen Replacement
Cosa ti serve
  1. Nike SportWatch GPS LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 1
    • First, place the watch upside down so the back of the watch is exposed. Unscrew the six size #000 5 mm long screws located on the back panel using a size 000 Phillips head screwdriver.
  2. Nike SportWatch GPS LCD Screen Replacement: passo 2, immagine 1 di 1
    • Carefully separate the watch by pulling the band away from the main board.
  3. Nike SportWatch GPS LCD Screen Replacement: passo 3, immagine 1 di 1
    • Then, unscrew the two main board size #000 2.5 mm long screws using a size 000 Phillips head screwdriver.
  4. Nike SportWatch GPS LCD Screen Replacement: passo 4, immagine 1 di 1
    • Carefully use the blue plastic opening tool to pry the main board out of the front panel.
    • Make sure to be gentle so the ribbon cable that connects to the band does not break, it is fragile and is not removable.
  5. Nike SportWatch GPS LCD Screen Replacement: passo 5, immagine 1 di 1
    • Use the blue plastic removal tool once again to carefully remove the screen.
  6. Nike SportWatch GPS LCD Screen Replacement: passo 6, immagine 1 di 1
    • Pull the plastic piece that is highlighted in the picture out from the back of the screen.
  7. Nike SportWatch GPS LCD Screen Replacement: passo 7, immagine 1 di 1
    • For reassembly, make sure the highlighted area in the picture, goes over the black plastic piece that was removed in the previous step.
Conclusione
Altre 3 persone hanno completato questa guida.
3 Commenti
Hello, I found your article very interesting, I was just wondering do you know where I can buy a replacement screen?
Thank you
Joseph Kermani - Replica
hello do you know where I can find a replacement screen ?
Thank you
SMOUN - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 3,447
