Salta al contenuto principale
Nike+ Sportband Motherboard Replacement
Cosa ti serve
  1. Nike+ Sportband Motherboard Replacement, External Case: passo 1, immagine 1 di 2 Nike+ Sportband Motherboard Replacement, External Case: passo 1, immagine 2 di 2
    • To begin the disassembly of your NikePlus Sportband, first remove the device from the rubber wristband.
  2. Nike+ Sportband Motherboard Replacement: passo 2, immagine 1 di 2 Nike+ Sportband Motherboard Replacement: passo 2, immagine 2 di 2
    • Finish the disassembly of your NikePlus Sportband by utilizing the metal spudger tool on the short edge to pry the external body pieces apart.
  3. Nike+ Sportband Motherboard Replacement, Screen: passo 3, immagine 1 di 2 Nike+ Sportband Motherboard Replacement, Screen: passo 3, immagine 2 di 2
    • After the cover had been removed, use the metal spudger tool to remove the body of the device from the casing.
  4. Nike+ Sportband Motherboard Replacement: passo 4, immagine 1 di 3 Nike+ Sportband Motherboard Replacement: passo 4, immagine 2 di 3 Nike+ Sportband Motherboard Replacement: passo 4, immagine 3 di 3
    • Use the metal tweezers to pry the screen casing from the body of the device.
    • The screen casing is fastened to the body of the device by four clips located in each corner of the casing.
  5. Nike+ Sportband Motherboard Replacement: passo 5, immagine 1 di 2 Nike+ Sportband Motherboard Replacement: passo 5, immagine 2 di 2
    • Flip the body of the device over so that the screen is now on the bottom.
    • The display ribbon cable is soldered to the motherboard. We were able to peel up the ribbon cable with a pair of tweezers.
    • Successfully resoldering this ribbon cable to the motherboard may prove difficult to the very small traces.
  6. Nike+ Sportband Motherboard Replacement: passo 6, immagine 1 di 3 Nike+ Sportband Motherboard Replacement: passo 6, immagine 2 di 3 Nike+ Sportband Motherboard Replacement: passo 6, immagine 3 di 3
    • Flip the body of the device back over so that the screen is facing up.
    • Using the tweezers, gently lift the screen from body of the device.
  7. Nike+ Sportband Motherboard Replacement, Motherboard: passo 7, immagine 1 di 1
    • Remove the four highlighted screws from the motherboard using the Philips screwdriver.
  8. Nike+ Sportband Motherboard Replacement: passo 8, immagine 1 di 3 Nike+ Sportband Motherboard Replacement: passo 8, immagine 2 di 3 Nike+ Sportband Motherboard Replacement: passo 8, immagine 3 di 3
    • Use the metal tweezers to lift the motherboard out of the device.
Conclusione
Alyssa Setnar
Membro da: 02/15/16
331 Reputazione
3 Guide realizzate
IUPUI, Team 9-9, Wilson Spring 2016 Membro di IUPUI, Team 9-9, Wilson Spring 2016
IUPUI-WILSON-S16S9G9
5 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 242
