Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Internal prereq..
  1. Remove the six Phillips screws securing the rear inner frame to the inner case.
    • Remove the six Phillips screws securing the rear inner frame to the inner case.
  2. Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
    • Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
    • Pry the opening tool upwards to pop the top right corner from the clips securing it to the inner assembly.
  3. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Acquista ora
    Acquista ora
  4. Insert the plastic opening tool to the right of the power button. Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
    • Insert the plastic opening tool to the right of the power button.
    • Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
  5. In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S. In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
    • In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
  6. Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
    • Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
  7. Lift and remove the rear inner frame from the Nexus S.
    • Lift and remove the rear inner frame from the Nexus S.
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 287
