Introduzione
The LED Board is responsible for that fancy light show the Nexus Q displays when functioning. Reaching the LED Board is most of the work when you want to replace it.
Cosa ti serve
Once you remove the ball bearing ring from the bottom half of the Nexus Q, you will be exposed to a diffuser (white ring) held in with three T6 Torx screws.
Use a #0 Philips head screwdriver to remove the three 0.8 mm screws holding the diffuser in place.
Conclusione
