Parti
Nessuna parte richiesta.
  1. Using the plastic opening tool, push the blade into the space between the case and lower cover.
    • Using the plastic opening tool, push the blade into the space between the case and lower cover.
    • Turn the opening tool slightly, the lower cover will detach on that side.
    • Repeat on other side of the seam.
    • The lower cover will slide off.
  2. Remove the one T5 Torx screw
    • Remove the one T5 Torx screw
    • Remove the one #00 Philips screw
    • Lift up the end of the antenna housing and slide it outwards.
    • The vibrator is located on the back of the antenna housing.
    • Use the spudger to pry up on the axle of the motor.
Conclusione
Niklas Johnson
Membro da: 31/01/2012
1.063 Reputazione
18 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,514
