Salta al contenuto principale
Nexus One Secondary Microphone Replacement
Cosa ti serve
  1. Nexus One Secondary Microphone Replacement, Rear Cover: passo 1, immagine 1 di 2 Nexus One Secondary Microphone Replacement, Rear Cover: passo 1, immagine 2 di 2
    • Using two fingers, push up on the rear cover.
  2. Nexus One Secondary Microphone Replacement: passo 2, immagine 1 di 1
    • The rear cover slides up and off.
  3. Nexus One Secondary Microphone Replacement, Battery: passo 3, immagine 1 di 1
    • Using the plastic opening tools, pry the left bottom corner of the battery up.
  4. Nexus One Secondary Microphone Replacement: passo 4, immagine 1 di 1
    • Pull the battery up and out.
  5. Nexus One Secondary Microphone Replacement, Battery Housing: passo 5, immagine 1 di 1
    • Remove the two Torx T5 screws.
    • Remove the one Philips #00 screw.
  6. Nexus One Secondary Microphone Replacement: passo 6, immagine 1 di 2 Nexus One Secondary Microphone Replacement: passo 6, immagine 2 di 2
    • Using the plastic opening tool, pry up the battery housing upwards.
    • Push pry tool down, undoing the plastic tab.
  7. Nexus One Secondary Microphone Replacement: passo 7, immagine 1 di 2 Nexus One Secondary Microphone Replacement: passo 7, immagine 2 di 2
    • Pry the upper left tab open on the battery housing.
  8. Nexus One Secondary Microphone Replacement: passo 8, immagine 1 di 2 Nexus One Secondary Microphone Replacement: passo 8, immagine 2 di 2
    • Pry the top tab of the battery housing.
  9. Nexus One Secondary Microphone Replacement: passo 9, immagine 1 di 2 Nexus One Secondary Microphone Replacement: passo 9, immagine 2 di 2
    • Pry the right side tab of the battery housing.
  10. Nexus One Secondary Microphone Replacement: passo 10, immagine 1 di 2 Nexus One Secondary Microphone Replacement: passo 10, immagine 2 di 2
    • Pull up on the battery housing.
    • Slide the battery housing out to remove it.
  11. Nexus One Secondary Microphone Replacement, Secondary Microphone: passo 11, immagine 1 di 2 Nexus One Secondary Microphone Replacement, Secondary Microphone: passo 11, immagine 2 di 2
    • Using the spudger, pry upwards on the second microphone connector.
  12. Nexus One Secondary Microphone Replacement: passo 12, immagine 1 di 1
    • Pull up on the ribbon cable, the tape will detach from the main board ribbon.
Conclusione
Niklas Johnson
Membro da: 01/31/12
1.207 Reputazione
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,256
