Introduzione
removing the lower cover
Parti
Nessuna parte richiesta.
  1. Using the plastic opening tool, push the blade into the space between the case and lower cover.
    • Using the plastic opening tool, push the blade into the space between the case and lower cover.
    • Turn the opening tool slightly, the lower cover will detach on that side.
    • Repeat on other side of the seam.
    • The lower cover will slide off.
Conclusione
Altre 3 persone hanno completato questa guida.
Niklas Johnson
Membro da: 31/01/2012
1.063 Reputazione
18 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,048
