Salta al contenuto principale
Nexus 9 USB Daughterboard Replacement
Cosa ti serve
  1. Nexus 9 USB Daughterboard Replacement, Rear Case: passo 1, immagine 1 di 3 Nexus 9 USB Daughterboard Replacement, Rear Case: passo 1, immagine 2 di 3 Nexus 9 USB Daughterboard Replacement, Rear Case: passo 1, immagine 3 di 3
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
  2. Nexus 9 USB Daughterboard Replacement, Vibrator Daughterboard: passo 2, immagine 1 di 1
    • Disconnect the two ZIF connectors attached to the daughterboards.
    • Gently pull on the ribbon cable to remove it.
  3. Nexus 9 USB Daughterboard Replacement: passo 3, immagine 1 di 2 Nexus 9 USB Daughterboard Replacement: passo 3, immagine 2 di 2
    • Remove the two 3mm T5 Torx screws securing the metal USB port bracket.
    • Use your fingers or a pair of tweezers to remove the bracket.
  4. Nexus 9 USB Daughterboard Replacement: passo 4, immagine 1 di 3 Nexus 9 USB Daughterboard Replacement: passo 4, immagine 2 di 3 Nexus 9 USB Daughterboard Replacement: passo 4, immagine 3 di 3
    • Unscrew the two 3mm T5 Torx screws securing the daughterboard to the device.
    • Use a pair of tweezers to disconnect the vibrator cable. It will lift straight up from the daughterboard connector.
    • Use your fingers to lift the daughterboard upward and out of the device.
  5. Nexus 9 USB Daughterboard Replacement: passo 5, immagine 1 di 1
    • The daughterboard has an orange ribbon cable that is adhered to the device. Gently pull the ribbon up and remove the daughtboard.
  6. Nexus 9 USB Daughterboard Replacement, USB Daughterboard: passo 6, immagine 1 di 1
    • Remove the single 3mm T5 Torx screw.
    • Use a spudger to disconnect the display ribbon cable ZIF connector.
    • Gently lift the USB daughterboard up from the device.
Conclusione
Altre 3 persone hanno completato questa guida.
Geoff Wacker
Membro da: 09/30/13
89.898 Reputazione
89 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 3,556
