Salta al contenuto principale
Nexus 9 Power and Volume Buttons Replacement
Cosa ti serve
  1. Nexus 9 Power and Volume Buttons Replacement, Rear Case: passo 1, immagine 1 di 3 Nexus 9 Power and Volume Buttons Replacement, Rear Case: passo 1, immagine 2 di 3 Nexus 9 Power and Volume Buttons Replacement, Rear Case: passo 1, immagine 3 di 3
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
  2. Nexus 9 Power and Volume Buttons Replacement, Battery: passo 2, immagine 1 di 2 Nexus 9 Power and Volume Buttons Replacement, Battery: passo 2, immagine 2 di 2
    • Carefully peel up the copper shielding with your fingers.
    • Before fully removing the copper shielding, make sure that the blue antenna cable is out of the way of the copper tab.
  3. Nexus 9 Power and Volume Buttons Replacement: passo 3, immagine 1 di 1
    • Using the spudger tool, carefully remove the bottom of the battery from it's location below the logic boards.
    • The battery is attached to the motherboard with some adhesive, so you may need an iOpener to loosen up the adhesive. Check out the iOpener guide for info on how to do it.
    • Do not pull the battery from the tablet yet, as it is still connected to the motherboard.
  4. Nexus 9 Power and Volume Buttons Replacement: passo 4, immagine 1 di 1
    • Now remove the metal clip covering the battery's connector cable located above the top left of the battery with the spudger.
    • After the metal clip is wiggled free, the battery's connector cable can be easily removed by just gently tugging it free.
  5. Nexus 9 Power and Volume Buttons Replacement: passo 5, immagine 1 di 1
    • The battery should now lift free of the tablet.
  6. Nexus 9 Power and Volume Buttons Replacement, Antenna Board: passo 6, immagine 1 di 2 Nexus 9 Power and Volume Buttons Replacement, Antenna Board: passo 6, immagine 2 di 2
    • This step is not necessary if you have already removed the battery.
  7. Nexus 9 Power and Volume Buttons Replacement: passo 7, immagine 1 di 1
    • Unscrew the three 3 mm Torx T5 screws on the antenna board.
    • This step and the next show the battery removed, but it is not necessary to remove it if you are only replacing the antenna board.
  8. Nexus 9 Power and Volume Buttons Replacement: passo 8, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Use your fingers or a pair of tweezers to disconnect the blue antenna cable from the motherboard.
    • When reinstalling the antenna, be sure to clean it with a degreaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to create wireless interference.
    • The antenna board should now lift free of the motherboard.
  9. Nexus 9 Power and Volume Buttons Replacement, Motherboard: passo 9, immagine 1 di 2 Nexus 9 Power and Volume Buttons Replacement, Motherboard: passo 9, immagine 2 di 2
    • Remove the three 3 mm T5 Torx screws.
    • Remove the five 2 mm Phillips #000 screws.
  10. Nexus 9 Power and Volume Buttons Replacement: passo 10, immagine 1 di 2 Nexus 9 Power and Volume Buttons Replacement: passo 10, immagine 2 di 2
    • Using your fingers, pull up on ribbon connector to expose another ribbon connector below.
    • Remove the two 2 mm Phillips #000 screws on top of the second ribbon connector.
    • Pull up the ribbon connector with your fingers.
  11. Nexus 9 Power and Volume Buttons Replacement: passo 11, immagine 1 di 1
    • Gently lift the motherboard up from the device.
  12. Nexus 9 Power and Volume Buttons Replacement: passo 12, immagine 1 di 1
  13. Nexus 9 Power and Volume Buttons Replacement, Power and Volume Buttons: passo 13, immagine 1 di 1
    • Using your tweezers, gently grasp the clear rubber backing and pull outward. The buttons should come free.
Conclusione
Altre 2 persone hanno completato questa guida.
Alden Simmer
Membro da: 02/05/15
370 Reputazione
1 Guida realizzata
Cal Poly, Team 19-11, Maness Winter 2015 Membro di Cal Poly, Team 19-11, Maness Winter 2015
CPSU-MANESS-W15S19G11
5 Membri
9 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 14
Tutti i Tempi: 2,025
