Introduzione
This guide will take approximately two hours, and involves the use of the iOpener for the adhesive located inside the board to be removed. In addition, all components of this device must be removed before the LCD can actually be removed.
Cosa ti serve
With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Use a spudger to disconnect the front-facing camera ZIF connector.
Use a pair of tweezers to gently lift the front-facing camera up from the motherboard.
Carefully peel up the copper shielding with your fingers.
Before fully removing the copper shielding, make sure that the blue antenna cable is out of the way of the copper tab.
Using the spudger tool, carefully remove the bottom of the battery from it's location below the logic boards.
The battery is attached to the motherboard with some adhesive, so you may need an iOpener to loosen up the adhesive. Check out the iOpener guide for info on how to do it.
Do not pull the battery from the tablet yet, as it is still connected to the motherboard.
Use a spudger or your fingers to remove the first speaker. The speaker may be heavily glued in and require heat to lift. Be careful as you can pull the speaker apart.
Use a pair of tweezers to remove the vibrator from the device.
Remove the three 3 mm T5 Torx screws.
Remove the five 2 mm Phillips #000 screws.
Refer to the rear-facing camera replacement guide to remove the rear-facing camera from the motherboard and transfer it to the new one.
The motherboard remains.
Remove the single 3mm T5 Torx screw.
Use a spudger to disconnect the display ribbon cable ZIF connector.
Gently lift the USB daughterboard up from the device.
Use a spudger or your fingers to remove the LCD connector from the display assembly.
Place the iOpener on the sides of the LCD where the adhesive is located beneath.
Let the iOpener sit for at least a minute to soften the adhesive beneath the glass.
This should be repeated for every side of the tablet, and each side will most likely need to be heated more than once.
Using the picks located in the iOpener Kit, insert the picks into the corners of the tablet, and move it back and forth along the sides of tablet.
Do this for every corner of the tablet until it is possible to pull the LCD from the display assembly with your finger.
The LCD should come completely free from the back assembly now by just leading the ribbon through the opening in the display assembly.
Altre 6 persone hanno completato questa guida.
2Commenti sulla guida
So I replaced the lcd abd glass but it won't display any thing when I turn it on I get haptic feedback and the led turns on but nothing on the screen I plugged it in and no battery charging display either I checked yto make sure the screen was not damaged in anyway what could be the problem ? I followed your guied to the letter ???
