Salta al contenuto principale
Nexus 5X Headphone Jack Replacement
Cosa ti serve
  1. Nexus 5X Headphone Jack Replacement, SIM Card Tray: passo 1, immagine 1 di 3 Nexus 5X Headphone Jack Replacement, SIM Card Tray: passo 1, immagine 2 di 3 Nexus 5X Headphone Jack Replacement, SIM Card Tray: passo 1, immagine 3 di 3
    • Insert a SIM card ejection tool into the hole on the SIM card tray, located on the left edge of the phone.
    • Press in to eject the SIM card tray.
    • Remove the SIM card tray.
  2. Nexus 5X Headphone Jack Replacement, Rear Panel: passo 2, immagine 1 di 3 Nexus 5X Headphone Jack Replacement, Rear Panel: passo 2, immagine 2 di 3 Nexus 5X Headphone Jack Replacement, Rear Panel: passo 2, immagine 3 di 3
    • Place an opening pick in the opening of the SIM card tray slot and twist it sideways to release the first plastic clip that holds the rear panel in its place.
    • Slide the opening pick around the top edge of the phone to release the plastic clips that secure the rear panel.
  3. Nexus 5X Headphone Jack Replacement: passo 3, immagine 1 di 3 Nexus 5X Headphone Jack Replacement: passo 3, immagine 2 di 3 Nexus 5X Headphone Jack Replacement: passo 3, immagine 3 di 3
    • Continue to slide the opening pick around all sides of the phone to release all clips that secure the rear panel.
  4. Nexus 5X Headphone Jack Replacement: passo 4, immagine 1 di 2 Nexus 5X Headphone Jack Replacement: passo 4, immagine 2 di 2
    • Tilt the opening pick to lift the rear panel a little bit.
    • There are two more plastic clips next to the fingerprint sensor. Release them by gently pulling the rear panel.
    • Remove the rear panel.
  5. Nexus 5X Headphone Jack Replacement, Midframe: passo 5, immagine 1 di 1
    • Remove the ten 3.6 mm Phillips screws that secure the midframe.
  6. Nexus 5X Headphone Jack Replacement: passo 6, immagine 1 di 2 Nexus 5X Headphone Jack Replacement: passo 6, immagine 2 di 2
    • Insert an opening pick into the SIM card tray slot and twist the opening pick sideways to release the plastic clips.
  7. Nexus 5X Headphone Jack Replacement: passo 7, immagine 1 di 2 Nexus 5X Headphone Jack Replacement: passo 7, immagine 2 di 2
    • Continue sliding the opening pick around the upper part of the midframe to release the plastic clips.
  8. Nexus 5X Headphone Jack Replacement: passo 8, immagine 1 di 2 Nexus 5X Headphone Jack Replacement: passo 8, immagine 2 di 2
    • Use the plastic pick to pry open the plastic clips on the long edge of the midframe and on the bottom edge.
    • Make sure the clips on the long edge are released. The midframe is prone to break here if they are not disconnected properly.
  9. Nexus 5X Headphone Jack Replacement: passo 9, immagine 1 di 2 Nexus 5X Headphone Jack Replacement: passo 9, immagine 2 di 2
    • Make sure all the clips are free.
    • Carefully remove the midframe.
  10. Nexus 5X Headphone Jack Replacement, Battery Disconnect: passo 10, immagine 1 di 2 Nexus 5X Headphone Jack Replacement, Battery Disconnect: passo 10, immagine 2 di 2
    • Use the edge of a spudger to pry up and disconnect the battery flex cable located at the bottom right of the motherboard.
  11. Nexus 5X Headphone Jack Replacement, Headphone Jack: passo 11, immagine 1 di 1
    • Use an iOpener on the bottom front of the screen for about 30 seconds to loosen the adhesive beneath the headphone jack.
  12. Nexus 5X Headphone Jack Replacement: passo 12, immagine 1 di 3 Nexus 5X Headphone Jack Replacement: passo 12, immagine 2 di 3 Nexus 5X Headphone Jack Replacement: passo 12, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Insert the pointed end of a spudger in the opening of the headphone jack.
    • Use the spudger to lever the headphone jack out of its gasket by tilting it upwards.
    • Remove the headphone jack with a pair of tweezers.
Conclusione
Apply new adhesive where it’s necessary.
Repair didn’t go as planned? Check out our Nexus 5X Answers community for troubleshooting help.
iFixit Membro di iFixit
Staff
124 Membri
24.148 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 36
Tutti i Tempi: 805
