Salta al contenuto principale
Nexus 5 SIM Card Replacement
Cosa ti serve
  1. Nexus 5 SIM Card Replacement, SIM Card: passo 1, immagine 1 di 2 Nexus 5 SIM Card Replacement, SIM Card: passo 1, immagine 2 di 2
    • Power off the device by holding the power button until the "Power Off" popup appears. Tap the popup and wait for the device to turn off.
    • Insert a SIM card eject tool or a paper clip into the hole next to the SIM card slot, which is located just under the power button. Do not force the paper clip if it is too thick; instead use the head of a sewing needle.
    • Push the tool into the hole until you see the card pop out.
  2. Nexus 5 SIM Card Replacement: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Gently remove the SIM card with your fingers, or a pair of tweezers if the SIM holder does not fully eject.
    • Make sure the chip is facing the rear of the phone when reinserting the SIM card.
Conclusione
Altre 2 persone hanno completato questa guida.
Kyle Libby
Membro da: 04/07/14
1.006 Reputazione
7 Guide realizzate
Cal Poly, Team 7-23, Regan Spring 2014 Membro di Cal Poly, Team 7-23, Regan Spring 2014
CPSU-REGAN-S14S7G23
4 Membri
19 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 36
Tutti i Tempi: 4,147
