Salta al contenuto principale
Nexus 4 Speaker Replacement
Cosa ti serve
  1. Nexus 4 Speaker Replacement, Back Cover: passo 1, immagine 1 di 2 Nexus 4 Speaker Replacement, Back Cover: passo 1, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    SIM Card Eject Tool
    $2.99
    Compra
    • Power off the phone, by long-pressing the power button and touching Power off.
    • Remove the SIM tray using the SIM Card Eject Tool.
    • This step is required in order to remove the back case.
  2. Nexus 4 Speaker Replacement: passo 2, immagine 1 di 1
    T5 Torx Screwdriver
    $5.49
    Compra
  3. Nexus 4 Speaker Replacement: passo 3, immagine 1 di 3 Nexus 4 Speaker Replacement: passo 3, immagine 2 di 3 Nexus 4 Speaker Replacement: passo 3, immagine 3 di 3
    • Gently open the back case by prying along the edge of the cover, starting at a corner of the phone and circling around the phone using a plastic opening tool.
    • The opening process may take a few minutes. The plastic will make a light snapping noise as the back cover separates from the rest of the phone.
  4. Nexus 4 Speaker Replacement, Battery: passo 4, immagine 1 di 2 Nexus 4 Speaker Replacement, Battery: passo 4, immagine 2 di 2
    • Remove the two 1.8 mm Phillips screws holding down the battery connector.
    • Using a plastic opening tool, disconnect the battery cable from its socket on the motherboard.
  5. Nexus 4 Speaker Replacement, Battery removal: passo 5, immagine 1 di 2 Nexus 4 Speaker Replacement, Battery removal: passo 5, immagine 2 di 2
    Plastic Cards
    $2.99
    Compra
    • Remove the blue tape that secures the white antenna cable to the battery.
    • Using a spudger, carefully disconnect the white antenna cable.
    • Carefully pry the battery out with a Plastic Opening Tool, starting at the top left-hand corner and working down towards the bottom right-hand corner.
    • If necessary, you can also use a plastic card to separate the battery from the metal midframe.
    • The battery is securely glued to the phone. When reinstalling the battery, press the battery firmly against the adhesive strip.
  6. Nexus 4 Speaker Replacement, Speaker: passo 6, immagine 1 di 2 Nexus 4 Speaker Replacement, Speaker: passo 6, immagine 2 di 2
    • Remove the two 4.8 mm screws that hold the speaker enclosure together using the Phillips 00 screwdriver.
  7. Nexus 4 Speaker Replacement: passo 7, immagine 1 di 2 Nexus 4 Speaker Replacement: passo 7, immagine 2 di 2
    • Gently pry the speaker up and away from the back of the phone using a plastic opening tool, and lift it out of the phone.
Conclusione
Altre 10 persone hanno completato questa guida.
Kaitlyn Jones
Membro da: 01/27/13
4.952 Reputazione
8 Guide realizzate
Cal Poly, Team 3-32, Amido Winter 2013 Membro di Cal Poly, Team 3-32, Amido Winter 2013
CPSU-AMIDO-W13S3G32
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 13,325
