Salta al contenuto principale
Nexus 10 Headphone Jack Replacement
Cosa ti serve
  1. Nexus 10 Headphone Jack Replacement, Battery: passo 1, immagine 1 di 3 Nexus 10 Headphone Jack Replacement, Battery: passo 1, immagine 2 di 3 Nexus 10 Headphone Jack Replacement, Battery: passo 1, immagine 3 di 3
    • Using a plastic opening tool, remove the thin plastic cover from back of the tablet by prying up from its small tab.
  2. Nexus 10 Headphone Jack Replacement: passo 2, immagine 1 di 1
    • Remove the five 2mm screws on the back of the device using a PH00 screwdriver.
  3. Nexus 10 Headphone Jack Replacement: passo 3, immagine 1 di 3 Nexus 10 Headphone Jack Replacement: passo 3, immagine 2 di 3 Nexus 10 Headphone Jack Replacement: passo 3, immagine 3 di 3
    • Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
    • Pull the the plastic backing off the display assembly using your hands.
    • Do not do this step with only your hands. You will require a significant amount of force to separate the device.
  4. Nexus 10 Headphone Jack Replacement: passo 4, immagine 1 di 3 Nexus 10 Headphone Jack Replacement: passo 4, immagine 2 di 3 Nexus 10 Headphone Jack Replacement: passo 4, immagine 3 di 3
    • Detach the three connector ribbons passing over the battery using the plastic opening tool.
  5. Nexus 10 Headphone Jack Replacement: passo 5, immagine 1 di 1
    • Remove the twelve 2mm screws around the perimeter of the battery with a PH00 screwdriver.
  6. Nexus 10 Headphone Jack Replacement: passo 6, immagine 1 di 2 Nexus 10 Headphone Jack Replacement: passo 6, immagine 2 di 2
    • Disconnect the battery by lifting it upward and pulling it away from the connector.
  7. Nexus 10 Headphone Jack Replacement, Headphone Jack: passo 7, immagine 1 di 1
    • Remove one screw on the logic board with a PH00 screwdriver.
  8. Nexus 10 Headphone Jack Replacement: passo 8, immagine 1 di 3 Nexus 10 Headphone Jack Replacement: passo 8, immagine 2 di 3 Nexus 10 Headphone Jack Replacement: passo 8, immagine 3 di 3
    • Disconnect right speaker connector ribbon from logic board.
    • Lift the speaker out by pulling up on its corner.
  9. Nexus 10 Headphone Jack Replacement: passo 9, immagine 1 di 3 Nexus 10 Headphone Jack Replacement: passo 9, immagine 2 di 3 Nexus 10 Headphone Jack Replacement: passo 9, immagine 3 di 3
    • Disconnect connectors around the perimeter of the motherboard.
  10. Nexus 10 Headphone Jack Replacement: passo 10, immagine 1 di 2 Nexus 10 Headphone Jack Replacement: passo 10, immagine 2 di 2
    • Remove motherboard by gently pulling upward under its corner.
  11. Nexus 10 Headphone Jack Replacement: passo 11, immagine 1 di 1
    • Remove the three 2mm screws along the right side of the device using a PH00 screwdriver.
  12. Nexus 10 Headphone Jack Replacement: passo 12, immagine 1 di 2 Nexus 10 Headphone Jack Replacement: passo 12, immagine 2 di 2
    • Unseat the small vibrator motor by gently applying upward pressure with a spudger.
  13. Nexus 10 Headphone Jack Replacement: passo 13, immagine 1 di 2 Nexus 10 Headphone Jack Replacement: passo 13, immagine 2 di 2
    • Lift the assembly by gently applying upward pressure with the spudger on the assembly.
  14. Nexus 10 Headphone Jack Replacement: passo 14, immagine 1 di 2 Nexus 10 Headphone Jack Replacement: passo 14, immagine 2 di 2
    • Gently pull battery-audio jack-USB assembly upward, detaching it from its adhesive.
Conclusione
Cal Poly, Team 34-18, Maness Spring 2016 Membro di Cal Poly, Team 34-18, Maness Spring 2016
CPSU-MANESS-S16S34G18
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 746
