Salta al contenuto principale
Nexus 10 Front Facing Camera Replacement
Cosa ti serve
  1. Nexus 10 Front Facing Camera Replacement, Front-Facing Camera: passo 1, immagine 1 di 3 Nexus 10 Front Facing Camera Replacement, Front-Facing Camera: passo 1, immagine 2 di 3 Nexus 10 Front Facing Camera Replacement, Front-Facing Camera: passo 1, immagine 3 di 3
    • Remove the plastic cover located on the back of the device by prying off one side of the cover with a plastic opening device and peeling it back.
  2. Nexus 10 Front Facing Camera Replacement: passo 2, immagine 1 di 3 Nexus 10 Front Facing Camera Replacement: passo 2, immagine 2 di 3 Nexus 10 Front Facing Camera Replacement: passo 2, immagine 3 di 3
    • Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
    • Pull the the plastic backing off the display assembly using your hands.
    • Do not do this step with only your hands. You will require a significant amount of force to separate the device.
  3. Nexus 10 Front Facing Camera Replacement: passo 3, immagine 1 di 3 Nexus 10 Front Facing Camera Replacement: passo 3, immagine 2 di 3 Nexus 10 Front Facing Camera Replacement: passo 3, immagine 3 di 3
    • Lift latch on front-facing camera connector.
    • Pull the connector toward the top of the device and remove the front-facing camera.
Conclusione
Cal Poly, Team 34-18, Maness Spring 2016 Membro di Cal Poly, Team 34-18, Maness Spring 2016
CPSU-MANESS-S16S34G18
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 601
