Salta al contenuto principale
Nextplay NP109CR Speakers Replacement
Cosa ti serve
  1. Nextplay NP109CR Speakers Replacement, Speakers: passo 1, immagine 1 di 1
    • Turn the device over so it is upside-down.
  2. Nextplay NP109CR Speakers Replacement: passo 2, immagine 1 di 1
    • Unscrew the 4 screws closest to the screen.
  3. Nextplay NP109CR Speakers Replacement: passo 3, immagine 1 di 1
    • Flip over the device so it is right side up.
  4. Nextplay NP109CR Speakers Replacement: passo 4, immagine 1 di 1
    • Unscrew the 2 screws on the top of the device, next to the docking plug.
  5. Nextplay NP109CR Speakers Replacement: passo 5, immagine 1 di 1
    • Take off top piece by using slight force and pulling off.
  6. Nextplay NP109CR Speakers Replacement: passo 6, immagine 1 di 1
    • Unscrew the button board with smaller screwdriver.
  7. Nextplay NP109CR Speakers Replacement: passo 7, immagine 1 di 1
    • Lift off the button board.
  8. Nextplay NP109CR Speakers Replacement: passo 8, immagine 1 di 1
    • Unscrew all visible of the screws on the black logic board cover with the larger screwdriver.
  9. Nextplay NP109CR Speakers Replacement: passo 9, immagine 1 di 1
    • Lift the screen vertically straight up.
    • As you do this the logic board should move off with it.
  10. Nextplay NP109CR Speakers Replacement: passo 10, immagine 1 di 1
    • Flip the screen and the logic board over to the right side.
  11. Nextplay NP109CR Speakers Replacement: passo 11, immagine 1 di 1
    • Pull out the white plug that goes from the speakers to the logic board.
    • Then plug back in making sure it is completely connected.
Conclusione
Michelle Read
Membro da: 09/26/12
1 Reputazione
1 Guida realizzata
Cal Poly, Team 7-50, Forte Fall 2012 Membro di Cal Poly, Team 7-50, Forte Fall 2012
CPSU-FORTE-F12S7G50
5 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 390
