Salta al contenuto principale
Introduzione
It's important to note that replacing the volume buttons includes using three prerequisite guides.
  1. Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers. Slide the opening tool to the right and slowly continue to separate the back cover from the device. Avoid prying on the buttons, as they are easily damaged.
    • Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
    • Slide the opening tool to the right and slowly continue to separate the back cover from the device.
    • Avoid prying on the buttons, as they are easily damaged.
  2. Pull the cover off of the device once about three quarters  of the cover has been pried open using the plastic opening tool.
    • Pull the cover off of the device once about three quarters of the cover has been pried open using the plastic opening tool.
  3. Remove masking tape from the battery.
    • Remove masking tape from the battery.
  4. Pry the battery from the base using the nylon spudger and move it away from the motherboard. Handle the battery with care to avoid damaging it. Handle the battery with care to avoid damaging it.
    • Pry the battery from the base using the nylon spudger and move it away from the motherboard.
    • Handle the battery with care to avoid damaging it.
  5. De-solder the three contact points and remove the battery. See the following guide for instructions on how to solder. Come saldare e dissaldare componenti elettriche Use caution when operating the soldering iron.
  6. Remove the two ZIF connectors attached to the motherboard by flipping up the black tabs before pulling the ribbon cable away. Only use a fingernail or nylon spudger to flip up the retaining flap. Using metal tools may damage delicate components. Only use a fingernail or nylon spudger to flip up the retaining flap. Using metal tools may damage delicate components.
    • Remove the two ZIF connectors attached to the motherboard by flipping up the black tabs before pulling the ribbon cable away.
    • Only use a fingernail or nylon spudger to flip up the retaining flap. Using metal tools may damage delicate components.
  7. Use the nut driver and J00 bit to remove the three 4 mm screws.
    • Use the nut driver and J00 bit to remove the three 4 mm screws.
  8. Peel back metal tape that is hiding the auxiliary port wires. Remove tape that is holding the speaker wires in place. Lift up on the motherboard to release it from the tablet.
    • Peel back metal tape that is hiding the auxiliary port wires.
    • Remove tape that is holding the speaker wires in place.
    • Lift up on the motherboard to release it from the tablet.
  9. De-solder volume buttons' eight contact points.
    • De-solder volume buttons' eight contact points.
    • Each button has 4 points of contact.
Conclusione
Michelle Helweh
Membro da: 30/10/2016
214 Reputazione
2 Guide realizzate
Baylor, Team 4-1, Williams Fall 2016 Membro di Baylor, Team 4-1, Williams Fall 2016
BU-WILLIAMS-F16S4G1
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 129
