Introduzione
If your pictures are blurry or losing quality, the front camera may need to be replaced. This guide will take you through the steps to replace the front camera which is quite easy. First you will disconnect the battery, then remove the front camera. The most difficult part will be removing the back cover, so please follow the steps carefully. The entire process is moderately difficult and will take you approximately 15 minutes to complete.
Cosa ti serve
With the tip of the thin metal spudger in place, use a prying motion to work the spudger down the side to the corner of the device.
