Salta al contenuto principale
Nextbook NEXT7P12-8G Camera Replacement
Cosa ti serve
  1. Nextbook NEXT7P12-8G Camera Replacement, Camera: passo 1, immagine 1 di 1
    • Use the plastic opening tool to pry apart the front and back covers of the Nextbook
    • Continue prying until the front and back covers are completely separated. Use the suction cup if necessary to pull apart
    • We recommend using an extra plastic opening tool to maintain your opening
  2. Nextbook NEXT7P12-8G Camera Replacement: passo 2, immagine 1 di 1
    • Once the front and back covers have been separated, set the back cover down and examine the interior of the Nextbook
    • Remove the various pieces of masking tape
  3. Nextbook NEXT7P12-8G Camera Replacement: passo 3, immagine 1 di 1
    • Carefully peel the battery pack off, starting from the outer edges
    • It is held down by an adhesive going diagonally across the back
    • Removing the battery will allow you to access the screws holding the chip in place
  4. Nextbook NEXT7P12-8G Camera Replacement: passo 4, immagine 1 di 1
    • Use a 4.0 bit screwdriver to remove the screws from the chip
  5. Nextbook NEXT7P12-8G Camera Replacement: passo 5, immagine 1 di 1
    • Remove the entire chip by severing small adhesive strips along the edges and pulling the chip away from the frame
    • Carefully peel away the black tape with copper detail that is holding the chip to the device
  6. Nextbook NEXT7P12-8G Camera Replacement: passo 6, immagine 1 di 1
    • Locate the camera
    • The camera will be a small black square directly behind the camera lens visible on the front side of the Nextbook
    • Pry the camera out of the front cover with the plastic opening tool
  7. Nextbook NEXT7P12-8G Camera Replacement: passo 7, immagine 1 di 1
    • Replace with a spare camera piece
Conclusione
Grace Cho
Membro da: 09/29/15
3 Reputazione
1 Guida realizzata
Ohio State, Team 2-2, Garvin Fall 2015 Membro di Ohio State, Team 2-2, Garvin Fall 2015
OSU-GARVIN-F15S2G2
3 Membri
2 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 818
