Salta al contenuto principale
Newport e360 Exhalation Flow Sensor Replacement
Cosa ti serve
  1. Newport e360 Exhalation Flow Sensor Replacement, Exhalation Flow Sensor: passo 1, immagine 1 di 1
    • Turn off ventilator before starting this repair.
    • Shut off or disconnect the air and oxygen gas supplies before starting this repair.
  2. Newport e360 Exhalation Flow Sensor Replacement: passo 2, immagine 1 di 1
    • To avoid damaging equipment, always use standard electrostatic discharge (ESD) precautions
    • Put on an ESD wrist strap or ESD gloves
  3. Newport e360 Exhalation Flow Sensor Replacement: passo 3, immagine 1 di 1
    • Open the Front Panel Door on the lower left front of the ventilator to expose Exhalation Valve EXH2105A and Flow Sensor FLS2101P.
  4. Newport e360 Exhalation Flow Sensor Replacement: passo 4, immagine 1 di 1
    • Remove the Exhalation Valve EXH2105A by releasing the retaining latch.
  5. Newport e360 Exhalation Flow Sensor Replacement: passo 5, immagine 1 di 1
    • Disconnect the Flow Sensor Cable CBL2123P from the plastic body of the Flow Sensor FLS2101P by pulling cable straight up. Do not twist.
  6. Newport e360 Exhalation Flow Sensor Replacement: passo 6, immagine 1 di 1
    • With a twisting motion, pull the plastic Flow Sensor FLS2101P away from the outlet of the Exhalation Valve EXH2105A.
Conclusione
Altre 2 persone hanno completato questa guida.
Lauren Ochoa
Membro da: 04/13/20
165 Reputazione
1 Guida realizzata
Cal Poly, Team S7-G21, Paton Spring 2020 Membro di Cal Poly, Team S7-G21, Paton Spring 2020
CPSU-PATON-S20S7G21
3 Membri
3 Guide realizzate
2Commenti sulla guida
I need this Exhalation Valve EXH2105A part, does anyone have a replacement?
Remigio Rodriguez - Replica
I need this
Cable NEWPORT GR-CBL2123P Flow Meter Parts P/N GR-CBL2123P
Please confirmwd to edisonmanullang@gmail.com
Thanks
Edison Simanullang - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 685
