Salta al contenuto principale
New Nintendo 2DS XL Motherboard Replacement
Cosa ti serve
  1. New Nintendo 2DS XL Motherboard Replacement, Back Cover Removal Preparation: passo 1, immagine 1 di 1
    • Before starting the disassembly, remove
    • The stylus
    • Any game cartridge
    • The SD card
    This is a great repair instructional, but I would advise also looking at the below video link. (I used both.) Sometimes watching 2 repair guides can help when you think you think you’re stuck. For example, I had a really hard time getting the hinge off!
    https://www.youtube.com/watch?v=Zuu_T2ls...
    (HINT: Works best if you rotate it 180 degrees, so that you are repairing it from the same perspective as the technician)
    skat1140 - Replica
  2. New Nintendo 2DS XL Motherboard Replacement, Back Cover Removal: passo 2, immagine 1 di 1
    • Unscrew the four 6mm tri-point screws located at the four corners of the bottom panel.
    The Y0 was too big; I ended up using a Y00 and that worked fine
    Christopher Gilmer-Hill - Replica
    Would not recommend using a Y000 like I tried to do
    Daniela Magaña-Ochoa - Replica
    gotta use Japanese Industry Standard YOO (blunt end)- I did not, and accidentally stripped two of the screws… still trying to figure out how to remove them -_-;
    Yanko Artidiello - Replica
    Yeah I can confirm, the y0 does not work.
    Arc Turus - Replica
    I'm using the Y-0.6 and seems to only unscrew 2 of the screws on the right side of the handheld, the other 2 aren't moving
    Xx_Definity_J0rd4n_xX - Replica
    screws are too tight
    Albert Einstien - Replica
  3. New Nintendo 2DS XL Motherboard Replacement, Case Separation: passo 3, immagine 1 di 2 New Nintendo 2DS XL Motherboard Replacement, Case Separation: passo 3, immagine 2 di 2
    • Be careful when separating the bottom panel from the front casing to avoid breaking the three cables connected to the motherboard (two on each side and one in the rear).
    • Using a spudger, separate the back panel from the front casing by gently prying around the panel.
    • There are many clips along the hinge of the case, so it is recommended to work your way along one short side and the two long sides before finishing the last short side.
    You need to be super careful separating the top from the bottom at the rear end. I got stuck there, applied a lil more force and ripped the right shoulder button straight off the pcb!
    Dominik Leicht - Replica
  4. New Nintendo 2DS XL Motherboard Replacement: passo 4, immagine 1 di 3 New Nintendo 2DS XL Motherboard Replacement: passo 4, immagine 2 di 3 New Nintendo 2DS XL Motherboard Replacement: passo 4, immagine 3 di 3
    • Using tweezers, disconnect the two cables that connect the rear buttons on either side to the motherboard by gently pulling them upwards.
    I unfortunately took off the base of one when trying to pull apart. Is there a fix or will it not be broken?
    Phoenix Typhoon - Replica
    Did you manage to fix this at all?
    Owen McKay -
    When you are putting these cables back, make sure to check the orientation of the cable. You have to match the cable head to the entry point, so you may have to turn the cable around. I spent a bit too much time trying to connect the cables just because I didn't realize that I had to turn the cable around.
    Hongda Wang - Replica
    Aren't these the speaker cables? I haven't taken any 2DS's apart in a while, but I'm pretty sure these cables connect to the speakers
    darth mango - Replica
  5. New Nintendo 2DS XL Motherboard Replacement, Battery Removal: passo 5, immagine 1 di 2 New Nintendo 2DS XL Motherboard Replacement, Battery Removal: passo 5, immagine 2 di 2
    • Using a spudger, lift out the battery.
    • Be aware that there is a sticky pad holding the battery into its tray. It may be necessary to use multiple tools to gently pry the battery away from the tray and motherboard.
    Some might see this as an optional step. But you probably do NOT want to skip this. I did, and now I have malfunctions on the Nintendo (touch screen functionality not working, possibly as a result of shorts from skipping this step.)
    skat1140 - Replica
    Personally, I skipped this step and everything still works fine. I wasn't able to take the battery out because the adhesive was too strong.
    Small square of adhesive. Pull up slowly and it’ll release after 10-20 seconds
    Jacob Cocanig - Replica
    Any advise for dealing with CTR-003 spicy pillow? So far in this transplant operation, both my devices batteries are okay... but... I dunno, if I were to run into a spicy pillow in the future, what would be the least awful way to pull it out?
    Not sorry, when I see these repair jobs that involve the company gluing the battery into the device (or even soddering in that soon to be spicy pillow) this is just something I'm wondering about
    Katrina Payne - Replica
    I haven't taken my 2ds apart yet, depending on how devices are built it might work to slide a solid thread (eg fishing rope, or floss but that might rip) under it, and do a sewing motion.
    Franziska (Natsu) -
  6. New Nintendo 2DS XL Motherboard Replacement, Motherboard: passo 6, immagine 1 di 2 New Nintendo 2DS XL Motherboard Replacement, Motherboard: passo 6, immagine 2 di 2
    • There are 8 ribbon cables that need to be removed as shown in the picture.
    • 2 of connectors (in green) are friction fit, unlike the rest of the connectors. Remove the cable by pulling it out gently. Do not attempt to open or unlatch these connectors in any way. Doing so will break them.
    • For the remaining 6 (in red), use a pair of tweezers to flip the latches up and pull the ribbon cable out.
    • Note that the second picture shows a broken ribbon connector next to the joystick ribbon connector (to the right of the red arrow). Do not attempt to unlatch this connector as shown in the picture!
    Do not just pull up “latches”, two of these are not zif connectors and pulling the top off will break it! I now have a dead 2DS XL because I followed this guide.
    Pressing the ZL button on device turns system off.
    Dunnymeister - Replica
    I made the same mistake. The guide is now updated.
    Mike -
    Trying to follow this guide... uh... what is a latch? That is a type of leverage based opening/closing device right? I'm not seeing anything on my board or in the images that I could call a "latch"
    I'm not able to find this locking mechanism described in the image... much less know what I am using tweezers on
    I would love to go further... but uh... there is no leverage based locking/closing/opening device in any of the images that I can see... no I can see on my board
    Oh right, and it doesn't take a psychic to know somebody is going to be all "ooh, why not Google it". After about a full page of ads, this is the Wikipedia entry for Latches. I do not see anything in the image, or on my board that matches that
    Katrina Payne -
    Okay update on how I got confused... turns out all the latches (except one) were already open. Apparently I tend to jostle my game device a bit on the hard side... and at some point they all (except one) came exceptionally loose. I literally could have just pulled the ribbon cables out
    On a related note... the reason my R-Button wasn't working wasn't due to stickiness... turns out I had somehow managed to push it so hard it depopulated itself from the board and was just sitting loose inside the case (well... as loose as it could be... it did not travel too much)... going to need to figure out how to repopulate the R-Button--looks like it could prolly be resoddered back in
    Prolly a good thing these repair guides exist
    But yeah... turns out all the clasps/latches whatever were completely open when I opened the case... that would prolly explain why the battery kept draining so quickly
  7. New Nintendo 2DS XL Motherboard Replacement: passo 7, immagine 1 di 2 New Nintendo 2DS XL Motherboard Replacement: passo 7, immagine 2 di 2
    • Unplug the following wires from the motherboard using a pair of tweezers.
  8. New Nintendo 2DS XL Motherboard Replacement: passo 8, immagine 1 di 2 New Nintendo 2DS XL Motherboard Replacement: passo 8, immagine 2 di 2
    • Remove the seven 4.4 mm screws using a J00 Phillips screwdriver bit.
    • Remove the motherboard from the device.
    Step 8 motherboard screws are J00 Phillips.
    Joseph Costello - Replica
    Thank You!!!
    Zach -
    Guide has been updated.
    Mike -
Conclusione
Altre 9 persone hanno completato questa guida.
IUPUI, Team S1-G4, Harley Fall 2019 Membro di IUPUI, Team S1-G4, Harley Fall 2019
IUPUI-HARLEY-F19S1G4
3 Membri
7 Guide realizzate
4 Commenti
On step 6, what is the top left circled connector for?
The screen on the device I am repairing keeping going black and this connector is damaged. (it doesn’t clamp shut)
Can anyone recommend where to buy a replacement board connector?
Billy Holliday - Replica
This doesn’t actually give ALL the tools you need. You can’t use a Tri point screwdriver on the CROSS screws that are in the pictures on the motherboard.
tomh1512 - Replica
I know this might be a year too late, but the tri point is required for removing the back plate of the system. If you don't have a small philips head laying around your house, idk what to tell ya
Zach Cunningham -
Followed on a 2ds having bad input feedback, no major issue. screws on motherboard are cross so you need a small one (most diy nintendo kits have one) and a small clamp (like the one in pictures) is mandatory for the 7 small cables. there is something a bit tricky regarding volume button which is a bit hard to get back in place when you reassemble the console, take care of pushing the inner slider to the most far position for easier mounting.
Arnaud “Kilbane” Jamet - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 13
Ultimi 7 Giorni: 86
Ultimi 30 Giorni: 516
Tutti i Tempi: 10,739
