Introduzione
This guide outlines the procedure for accessing the device circle pad. To access the circle pad, the entire device must be opened. This might be intimidating at first, but as long as the guide directions are followed, no damage to the device is expected. For more information, refer to our troubleshooting page.
Strumenti
Parti
Nessuna parte specificata.
Before starting the disassembly, remove
The stylus
Any game cartridge
The SD card
Unscrew the four 6mm tri-point screws located at the four corners of the bottom panel.
Using a spudger, separate the back panel from the front casing by gently prying around the panel.
There are many clips along the hinge of the case, so it is recommended to work your way along one short side and the two long sides before finishing the last short side.
Using tweezers, disconnect the two cables that connect the rear buttons on either side to the motherboard by gently pulling them upwards.
I unfortunately took off the base of one when trying to pull apart. Is there a fix or will it not be broken?
Using a spudger, lift out the battery.
Be aware that there is a sticky pad holding the battery into its tray. It may be necessary to use multiple tools to gently pry the battery away from the tray and motherboard.
To more easily access this ribbon cable, flip the device so the back casing faces upwards. Gently slide the back casing forward, revealing the ribbon cable connecting to the motherboard.
Using a spudger, pry up the ZIF connector holding the ribbon cable.
Pull the ribbon towards the bottom casing and out of the connector.
Remove the two 7.5mm phillips screws using a PH000 screwdriver.
Gently flip over the circle pad. Be aware that the pad is pressed into the back of the circle pad on the front of the case. Gentle prying will be necessary to pry if from the back of the circle pad.
Be aware that there is a black plastic disc that sits between the circle pad module and the circle pad stick. During reassembly, stand the unit on end and hang the plastic disc on the circle pad module and hold the stick from the front to press them back together.
2 Commenti
Excellent guide, although I believe the 2ds XL requires a Y00 and not a Y0
This is a great repair instructional, but I would advise also looking at the below video link. (I used both.) Sometimes watching 2 repair guides can help when you think you think you’re stuck. For example, I had a really hard time getting the hinge off!
https://www.youtube.com/watch?v=Zuu_T2ls...
(HINT: Works best if you rotate it 180 degrees, so that you are repairing it from the same perspective as the technician)
skat1140 - Replica
