Salta al contenuto principale
NeuTab N7 Pro Camera Replacement
Cosa ti serve
  1. NeuTab N7 Pro Camera Replacement, Camera: passo 1, immagine 1 di 1
    • Power off your device before beginning disassembly
    • Insert plastic opening tool and pry back case away, slowly moving the plastic opening tool along the device.
  2. NeuTab N7 Pro Camera Replacement: passo 2, immagine 1 di 1
    • Locate the camera unit and note where it is attached to the motherboard.
    • Use a black nylon spudger to remove the adhesive holding it onto to the motherboard.
    • Metal tools can puncture an unprotected battery, potentially causing a fire. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device.
  3. NeuTab N7 Pro Camera Replacement: passo 3, immagine 1 di 2 NeuTab N7 Pro Camera Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use a black nylon spudger or tweezers to release the connector holding the camera ribbon cable in place.
    • Carefully pull the ribbon cable out, removing the camera from the motherboard.
Conclusione
USF Tampa, Team 7-1, Cheng Spring 2016 Membro di USF Tampa, Team 7-1, Cheng Spring 2016
USFT-CHENG-S16S7G1
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 219
