Introduzione
This is a step-by-step guide on how to remove the lens assembly PCB board in a Netgear Arlo. Remove the batteries before beginning this guide.
  1. Remove the 2 (3.5mm) housing screws with a J0 screwdriver.
    • Remove the 2 (3.5mm) housing screws with a J0 screwdriver.
  2. Slide the unlocked battery cover forward to remove 2 (3.5mm) screws, that are behind the cover. Slide the unlocked battery cover forward to remove 2 (3.5mm) screws, that are behind the cover.
    • Slide the unlocked battery cover forward to remove 2 (3.5mm) screws, that are behind the cover.
  3. Open the battery cover and remove the  2 (3.5mm") screws from under the cover.
    • Open the battery cover and remove the 2 (3.5mm") screws from under the cover.
  4. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  5. Use a plastic opening tool to start separating the plastic housing from the front side of the battery cover. Next,  start separating the plastic cover from the rear of the plastic housing, and work your way down the seam line. Make sure the plastics snaps on the front of the plastic get unhooked from the grey plastic ring around the front of the camera.
    • Use a plastic opening tool to start separating the plastic housing from the front side of the battery cover.
    • Next, start separating the plastic cover from the rear of the plastic housing, and work your way down the seam line.
    • Make sure the plastics snaps on the front of the plastic get unhooked from the grey plastic ring around the front of the camera.
  6. Remove the screw (3.5mm) near the sync button holding the opposite side of the camera on. Remove the second screw (3.5mm) on the back of the camera to remove the second housing. Once the screws are removed use an opening tool to pry back the second plastic mount.
    • Remove the screw (3.5mm) near the sync button holding the opposite side of the camera on.
    • Remove the second screw (3.5mm) on the back of the camera to remove the second housing.
    • Once the screws are removed use an opening tool to pry back the second plastic mount.
  7. Remove 4 (6mm) large screws with a J00 screwdriver.
    • Remove 4 (6mm) large screws with a J00 screwdriver.
    • There are 2 on each side. This will allow you to remove the clear housing from the white housing.
  8. Once screws are removed, pull apart the clear housing. Remove rod from camera cover.
    • Once screws are removed, pull apart the clear housing.
    • Remove rod from camera cover.
  9. Remove Large ribbon cable first to disconnect front of camera from main body. Remove 4 (3.5mm) small black screws from motherboard of the camera unit. Remove smaller ribbon cable from underneath yellow tape.
    • Remove Large ribbon cable first to disconnect front of camera from main body.
    • Remove 4 (3.5mm) small black screws from motherboard of the camera unit.
    • Remove smaller ribbon cable from underneath yellow tape.
  10. Once all ribbon cables are removed, remove the motherboard and camera assembly by pulling up on the black camera motherboard.
    • Once all ribbon cables are removed, remove the motherboard and camera assembly by pulling up on the black camera motherboard.
Conclusione
Connor Krampen
Membro da: 08/01/2018
375 Reputazione
3 Guide realizzate
IUPUI, Team S1-G1, Freund Spring 2018 Membro di IUPUI, Team S1-G1, Freund Spring 2018
IUPUI-FREUND-S18S1G1
2 Membri
3 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 48
Tutti i Tempi: 794
