Introduzione
A quick and simple guide for replacing the infrared LED board in the Netgear Arlo security camera.
Cosa ti serve
Remove Large ribbon cable first to disconnect front of camera from main body.
Remove 4 (3.5mm) small black screws from motherboard of the camera unit.
Remove smaller ribbon cable from underneath yellow tape.
Remove 3 (.150") screws from the sync board using the JIS00 screwdriver.
3 Commenti
Great tutorial, thanks a lot.
I have a problem with infrared, Netgear isn’t able to help me without seeing the camera.
I would like to ask you….
In the night the red leds light on but you see all black, there is no light entering in the lens system. I think there is a problem in the diaphragm… what do you think?
The first months it works correctly (except once when I see all pink, I fix it restarted the camera).
Thank you!
Matteo
matteor84@hotmail.it
Where can you buy the board and other parts?
I’d like to know too. This repair guide is no help if you can’t buy the parts needed to complete the repair.
