Introduzione
Replacing the base plate for your Nest couldn't be easier. The only tool required is a Phillips #2 screwdriver
Cosa ti serve
Grasp the display's outer ring with your fingers and pull directly away while rotating clockwise to remove the thermostat from the wall.
Go to the electrical panel and turn off the circuit to make sure no power is running to the thermostat.
Once the power is off, disconnect the Y1, G, R, W1, C, and OB wires.
