Salta al contenuto principale
Nest Hello O-Ring Replacement
Cosa ti serve
  1. Nest Hello O-Ring Replacement, Casing and Faceplate: passo 1, immagine 1 di 1
    • Insert the pick between the black faceplate and white casing of the Nest Hello.
    • Pry the faceplate away from the device with the opening pick.
    • If you have not opened the Nest Hello before, there will be a protective foam mesh that is glued to the plastic covering and the inside of the mesh, use a pick to cut through the mesh as much as possible.
    • Completely remove the faceplate from the device, do not be afraid to pull hard.
  2. Nest Hello O-Ring Replacement: passo 2, immagine 1 di 2 Nest Hello O-Ring Replacement: passo 2, immagine 2 di 2
    • Peel back the cover stickers and use the Phillips #000 screwdriver to remove the four screws.
  3. Nest Hello O-Ring Replacement: passo 3, immagine 1 di 3 Nest Hello O-Ring Replacement: passo 3, immagine 2 di 3 Nest Hello O-Ring Replacement: passo 3, immagine 3 di 3
    • Insert opening pick between the white casing and the black internal circuitry and pry it out.
    • There is a ribbon cable connecting the white casing to the circuit boards. Be careful not to tear out the cable while separating the casing from the circuit boards.
  4. Nest Hello O-Ring Replacement, O-Ring: passo 4, immagine 1 di 1
    • Remove the O-Ring (colored blue) from the device. It is placed around the edge of the motherboard.
Conclusione
Altre 3 persone hanno completato questa guida.
2Commenti sulla guida
Is there a link available for spare replacement parts? I can’t seem to find anything other than replacement internal batteries . Thanks!
Andres Chavez - Replica
Also looking for this replacement part. Googling did not produce results.
KB_KB - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 129
Tutti i Tempi: 4,602
