Introduzione
The motherboard functions as the central hub of communication between all of the components in a device. If your device isn’t functioning properly and if multiple components are failing, the motherboard may need to be replaced. Use this guide to replace the motherboard in the Nest Hello.
Cosa ti serve
Insert the pick between the black faceplate and white casing of the Nest Hello.
Pry the faceplate away from the device with the opening pick.
Completely remove the faceplate from the device, do not be afraid to pull hard.
Use the Phillips #000 to remove the two screws holding the ribbon cable to the white casing.
2 Commenti
@viteapen13 Hi Daniel, question for you. On step 9, is the enclosing shell for the main board (top portion of the photo) metallic or plastic? Also, the blue material off the shell foam? Last, the blue regular stuff from the bottom board, is that some kind of thermal paste? Thanks.
