Salta al contenuto principale
Nest Hello Casing and Faceplate Replacement
Cosa ti serve
  1. Nest Hello Casing and Faceplate Replacement, Casing and Faceplate: passo 1, immagine 1 di 1
    • Insert the pick between the black faceplate and white casing of the Nest Hello.
    • Pry the faceplate away from the device with the opening pick.
    • If you have not opened the Nest Hello before, there will be a protective foam mesh that is glued to the plastic covering and the inside of the mesh, use a pick to cut through the mesh as much as possible.
    • Completely remove the faceplate from the device, do not be afraid to pull hard.
  2. Nest Hello Casing and Faceplate Replacement: passo 2, immagine 1 di 2 Nest Hello Casing and Faceplate Replacement: passo 2, immagine 2 di 2
    • Peel back the cover stickers and use the Phillips #000 screwdriver to remove the four screws.
  3. Nest Hello Casing and Faceplate Replacement: passo 3, immagine 1 di 3 Nest Hello Casing and Faceplate Replacement: passo 3, immagine 2 di 3 Nest Hello Casing and Faceplate Replacement: passo 3, immagine 3 di 3
    • Insert opening pick between the white casing and the black internal circuitry and pry it out.
    • There is a ribbon cable connecting the white casing to the circuit boards. Be careful not to tear out the cable while separating the casing from the circuit boards.
Conclusione
2 Commenti
Are Replacement parts available anywhere? Can’t seem to find anything… thanks!
Andres Chavez - Replica
Aside from fine grit sanding and spray painting or using a silicone cover, has anyone found a creative way to fix the delaminated an existing Gen 1 Google Nest wired / Nest Hello doorbell faceplate (remove the rest of the flaking off laminate)?
RickSoFlo - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 71
Tutti i Tempi: 2,049
