Introduzione
If your Nest Hello is losing charge faster than it used to, or refusing to power-on despite troubleshooting, this guide will help you access a faulty battery. The following steps will require the iFixit opening picks, Phillips #000 screwdriver, and tweezers. While removing the faceplate and casing from the device it is easy to damage the waterproofing O-Ring, so plan on replacing that as well.
Strumenti
Parti
Nessuna parte specificata.
Insert the pick between the black faceplate and white casing of the Nest Hello.
Pry the faceplate away from the device with the opening pick.
Completely remove the faceplate from the device, do not be afraid to pull hard.
Use the Phillips #000 to remove the two screws holding the ribbon cable to the white casing.
Once the back casing is removed, disconnect the battery cable and remove the battery from the device.
4 Commenti
Any recommendations as to where we can find a replacement battery? Model #, specs?
What is the replacement battery?
Bonjour, j’ai besoin de changer la batterie.
Merci pour le tuto,
avez vous un liens pour la batterie svp ?
urgent
