Salta al contenuto principale
Nest Dropcam Pro Micro-USB Port Replacement
Cosa ti serve
  1. Nest Dropcam Pro Micro-USB Port Replacement, Outer Case: passo 1, immagine 1 di 1
    • Press in the mounting clips on each side of the case to remove the camera from the mount.
  2. Nest Dropcam Pro Micro-USB Port Replacement: passo 2, immagine 1 di 2 Nest Dropcam Pro Micro-USB Port Replacement: passo 2, immagine 2 di 2
    • Using a Philips #0 screwdriver, remove the four 3 mm screws.
  3. Nest Dropcam Pro Micro-USB Port Replacement: passo 3, immagine 1 di 2 Nest Dropcam Pro Micro-USB Port Replacement: passo 3, immagine 2 di 2
    • Lift the front of the case slowly, as there is an antenna cable attached to the motherboard.
    • Carefully disconnect the antenna cable from the motherboard. You will feel this cable "pop" out of place when disconnected.
  4. Nest Dropcam Pro Micro-USB Port Replacement, Motherboard: passo 4, immagine 1 di 2 Nest Dropcam Pro Micro-USB Port Replacement, Motherboard: passo 4, immagine 2 di 2
    • Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case.
  5. Nest Dropcam Pro Micro-USB Port Replacement: passo 5, immagine 1 di 2 Nest Dropcam Pro Micro-USB Port Replacement: passo 5, immagine 2 di 2
    • Pull the motherboard away from the back case.
    • Unplug the red and black cable connecting the motherboard to the back case.
  6. Nest Dropcam Pro Micro-USB Port Replacement: passo 6, immagine 1 di 2 Nest Dropcam Pro Micro-USB Port Replacement: passo 6, immagine 2 di 2
    • Using a Philips #0 screwdriver, remove the four 2 mm screws.
  7. Nest Dropcam Pro Micro-USB Port Replacement: passo 7, immagine 1 di 2 Nest Dropcam Pro Micro-USB Port Replacement: passo 7, immagine 2 di 2
    • Lift the lens and LED assembly away from the motherboard.
    • Unplug the yellow and white cable from the motherboard.
  8. Nest Dropcam Pro Micro-USB Port Replacement, Micro-USB Port: passo 8, immagine 1 di 2 Nest Dropcam Pro Micro-USB Port Replacement, Micro-USB Port: passo 8, immagine 2 di 2
    • Using a soldering station and desoldering braid, desolder the four points surrounding the Micro-USB port.
    • Lift the Micro-USB port away from the motherboard.
Conclusione
Altre 4 persone hanno completato questa guida.
David Foens
Membro da: 09/03/15
893 Reputazione
6 Guide realizzate
USF Tampa, Team 15-4, Blackwell Fall 2015 Membro di USF Tampa, Team 15-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G4
3 Membri
12 Guide realizzate
4 Commenti
I don't have the soldering tools but I used lazerbond to reattach the old port. I hope all the conductors are touching their counter parts. I haven't plugged it back in yet. Wish me luck.
Kreschendalyn Backus - Replica
Did it work for you?
Michael Candy -
Where can you order the micro-usb charge port for this cam?
Danny Acevedo - Replica
Not sure where you get them but according to one site it uses a Micro USB 2.0 Type B Receptacle.
https://bit.ly/2Kg01z6
Debbie - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 17
Tutti i Tempi: 5,701
