Introduzione
This guide is used to replace the camera lens of the Nest Dropcam Pro. Make sure the device is unplugged before opening.
Cosa ti serve
Press in the mounting clips on each side of the case to remove the camera from the mount.
Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case.
Altre 2 persone hanno completato questa guida.
2 Commenti
Where do you get replacement lens?
