Salta al contenuto principale
Nest Cam Side Snap Locks Replacement
Cosa ti serve
  1. Nest Cam Side Snap Locks Replacement, Side Snap Locks: passo 1, immagine 1 di 1
    • Remove the four 6 mm screws from the back panel with the J000 Phillips head screwdriver.
    • We suggest designated areas to keep track of all screws.
  2. Nest Cam Side Snap Locks Replacement: passo 2, immagine 1 di 3 Nest Cam Side Snap Locks Replacement: passo 2, immagine 2 di 3 Nest Cam Side Snap Locks Replacement: passo 2, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Open the back panel completely to expose the inside of the Nest Cam.
    • Using the tweezers, disconnect the red and black mic cable from the motherboard.
  3. Nest Cam Side Snap Locks Replacement: passo 3, immagine 1 di 3 Nest Cam Side Snap Locks Replacement: passo 3, immagine 2 di 3 Nest Cam Side Snap Locks Replacement: passo 3, immagine 3 di 3
    • Disconnect the black Wi-Fi cable from the top of the motherboard with tweezers.
    • Use a plastic spudger to lift the motherboard and camera up enough to expose and disconnect the white cable with the tweezers.
    • Remove motherboard and camera completely from the housing.
  4. Nest Cam Side Snap Locks Replacement: passo 4, immagine 1 di 2 Nest Cam Side Snap Locks Replacement: passo 4, immagine 2 di 2
    • Remove the four 3 mm Phillips #J000 screws from the side snap locks. Remove the old side snap locks and place the new side snap locks.
    • Make sure everything lines up for the screws.
Conclusione
Lisa Langley
Membro da: 02/24/16
207 Reputazione
1 Guida realizzata
USF Tampa, Team 1-1, Leahy Spring 2016 Membro di USF Tampa, Team 1-1, Leahy Spring 2016
USFT-LEAHY-S16S1G1
7 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,994
