Salta al contenuto principale
Nest Cam Outdoor S Plastic Camera Cover Replacement
Cosa ti serve
  1. Nest Cam Outdoor S Plastic Camera Cover Replacement, Plastic Camera Cover: passo 1, immagine 1 di 2 Nest Cam Outdoor S Plastic Camera Cover Replacement, Plastic Camera Cover: passo 1, immagine 2 di 2
    • Wedge a spudger between the black front panel and the white outer shell.
    • Slide the spudger around the edge of the panel to pop it off.
  2. Nest Cam Outdoor S Plastic Camera Cover Replacement: passo 2, immagine 1 di 1
    • Remove the four small screws from the plastic camera cover.
  3. Nest Cam Outdoor S Plastic Camera Cover Replacement: passo 3, immagine 1 di 1
    • Disconnect the microphone cable to separate the motherboard from the main camera unit.
  4. Nest Cam Outdoor S Plastic Camera Cover Replacement: passo 4, immagine 1 di 2 Nest Cam Outdoor S Plastic Camera Cover Replacement: passo 4, immagine 2 di 2
    • Remove the plastic camera cover from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 540
