Salta al contenuto principale
Nest Cam Outdoor S Battery Replacement
Cosa ti serve
  1. Nest Cam Outdoor S Battery Replacement, Plastic Camera Cover: passo 1, immagine 1 di 2 Nest Cam Outdoor S Battery Replacement, Plastic Camera Cover: passo 1, immagine 2 di 2
    • Wedge a spudger between the black front panel and the white outer shell.
    • Slide the spudger around the edge of the panel to pop it off.
  2. Nest Cam Outdoor S Battery Replacement: passo 2, immagine 1 di 1
    • Remove the four small screws from the plastic camera cover.
  3. Nest Cam Outdoor S Battery Replacement: passo 3, immagine 1 di 1
    • Disconnect the microphone cable to separate the motherboard from the main camera unit.
  4. Nest Cam Outdoor S Battery Replacement: passo 4, immagine 1 di 2 Nest Cam Outdoor S Battery Replacement: passo 4, immagine 2 di 2
    • Remove the plastic camera cover from the device.
  5. Nest Cam Outdoor S Battery Replacement, Battery: passo 5, immagine 1 di 2 Nest Cam Outdoor S Battery Replacement, Battery: passo 5, immagine 2 di 2
    • Wedge a nylon spudger between the white outer shell and the battery.
    • Slowly pull the battery away from the plastic camera cover.
    • The battery is only held on with glue.
Conclusione
3 Commenti
Do you have the P/N of the battery??
Richard K Yabuki - Replica
Where to buy a replacement battery?
Ted McKenna - Replica
I believe the battery model is GS24 (3.65V, 600 mAh/21.9Wh).
I also saw this on the battery
GPN: G823-00181-01
Dung Huynh - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 50
Ultimi 30 Giorni: 227
Tutti i Tempi: 6,907
