Salta al contenuto principale
Nest Cam Motherboard Replacement
Cosa ti serve
  1. Nest Cam Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Remove the four 6 mm screws from the back panel with the JIS 000 screwdriver.
    • We suggest designated areas to keep track of all screws.
  2. Nest Cam Motherboard Replacement: passo 2, immagine 1 di 3 Nest Cam Motherboard Replacement: passo 2, immagine 2 di 3 Nest Cam Motherboard Replacement: passo 2, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Open the back panel completely to expose the inside of the Nest Cam.
    • Using the tweezers, disconnect the red and black mic cable from the motherboard.
  3. Nest Cam Motherboard Replacement: passo 3, immagine 1 di 2 Nest Cam Motherboard Replacement: passo 3, immagine 2 di 2
    • Remove the two 4 mm screws with the JIS 000 screwdriver from the center.
    • Disconnect the black Wi-Fi cable from the motherboard with the tweezers.
  4. Nest Cam Motherboard Replacement: passo 4, immagine 1 di 3 Nest Cam Motherboard Replacement: passo 4, immagine 2 di 3 Nest Cam Motherboard Replacement: passo 4, immagine 3 di 3
    • Use a plastic spudger to lift the motherboard slightly up to expose and disconnect the white cable and the yellow/white IR cable with tweezers.
    • Then use the spudger or a finger to lift the motherboard completely up and off.
    • When installing the new motherboard ensure that all wires are reconnected before securing.
Conclusione
Altre 5 persone hanno completato questa guida.
Khiry Jones
Membro da: 02/29/16
159 Reputazione
1 Guida realizzata
USF Tampa, Team 1-1, Leahy Spring 2016 Membro di USF Tampa, Team 1-1, Leahy Spring 2016
USFT-LEAHY-S16S1G1
7 Membri
10 Guide realizzate
4 Commenti
where can I get a MoBo for my drop cam?
mikelebp1 - Replica
where can i find a motherboard replacement?
Steve - Replica
I have a Nest Outdoor IQ Camera. The Camera is Dead. Would love to Replace the Motherboard. Where can I get one ???
pmwenc@aol.com - Replica
same here, no where to be found online
chantalder - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 37
Tutti i Tempi: 24,420
