Salta al contenuto principale
Nest Cam IQ Mounting Stand Replacement
Cosa ti serve
  1. Nest Cam IQ Mounting Stand Replacement, Mounting Stand: passo 1, immagine 1 di 1
    • To soften the adhesive holding the camera together, heat up the edges of the glass lens using a heated iOpener on the device. Alternatively, you can use a heat gun to loosen the adhesive.
    • Leave the Opener on the glass lens for two minutes.
    • Be careful not to burn yourself while handling the hot iOpener. For more information on the Opener, use the iOpener Instructions Guide.
  2. Nest Cam IQ Mounting Stand Replacement: passo 2, immagine 1 di 1
    • Use an opening tool to split apart the glass lens from the body.
    • Be careful to not break the glass when prying from the body.
  3. Nest Cam IQ Mounting Stand Replacement: passo 3, immagine 1 di 1
    • Place a suction cup on the glass lens that you heated up with the iOpener.
    • Press down on the suction cup to create a seal, and pull up with force to create a separation between the glass lens and the body.
    • Pull off the glass lens using the suction cup.
  4. Nest Cam IQ Mounting Stand Replacement: passo 4, immagine 1 di 2 Nest Cam IQ Mounting Stand Replacement: passo 4, immagine 2 di 2
    • Carefully disconnect the flat black ribbon cable connecting the metal plate to the LED.
    • Remove the metal plate.
  5. Nest Cam IQ Mounting Stand Replacement: passo 5, immagine 1 di 2 Nest Cam IQ Mounting Stand Replacement: passo 5, immagine 2 di 2
    • Remove the five 9mm TR6 Torx screws from the LED cover.
    • Pull off the LED cover.
    • As you remove the LED cover, be careful not to tear the flat black ribbon connecting the LED to the motherboard.
  6. Nest Cam IQ Mounting Stand Replacement: passo 6, immagine 1 di 3 Nest Cam IQ Mounting Stand Replacement: passo 6, immagine 2 di 3 Nest Cam IQ Mounting Stand Replacement: passo 6, immagine 3 di 3
    • Carefully disconnect the flat black ribbon cable connecting the LED to the motherboard.
    • Remove the LED cover.
  7. Nest Cam IQ Mounting Stand Replacement: passo 7, immagine 1 di 1
    • Remove the two 7mm TR6 Torx screws securing the camera.
    • Carefully pull out the camera.
    • As you remove the camera, be careful not to tear the flat black ribbon connecting the camera to the motherboard.
  8. Nest Cam IQ Mounting Stand Replacement: passo 8, immagine 1 di 2 Nest Cam IQ Mounting Stand Replacement: passo 8, immagine 2 di 2
    • Carefully disconnect the flat black ribbon cable connecting the camera to the motherboard.
    • Remove the camera.
  9. Nest Cam IQ Mounting Stand Replacement: passo 9, immagine 1 di 3 Nest Cam IQ Mounting Stand Replacement: passo 9, immagine 2 di 3 Nest Cam IQ Mounting Stand Replacement: passo 9, immagine 3 di 3
    • Remove the three 19mm TR6 Torx screws from the camera holder.
    • Carefully lift the tab up and away from the camera holder.
    • Remove the camera holder.
  10. Nest Cam IQ Mounting Stand Replacement: passo 10, immagine 1 di 2 Nest Cam IQ Mounting Stand Replacement: passo 10, immagine 2 di 2
    • Remove the one 4mm TR6 Torx screw from the clear cover.
    • Remove the clear cover.
  11. Nest Cam IQ Mounting Stand Replacement: passo 11, immagine 1 di 3 Nest Cam IQ Mounting Stand Replacement: passo 11, immagine 2 di 3 Nest Cam IQ Mounting Stand Replacement: passo 11, immagine 3 di 3
    • Remove the four 11mm TR6 Torx screws from the clamp securing the mounting stand.
    • Remove the clamp.
    • Carefully pull away the cables connecting the mounting stand to the body.
  12. Nest Cam IQ Mounting Stand Replacement: passo 12, immagine 1 di 1
    • Carefully remove the mounting stand.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 72
