Introduzione
If your Nest Cam IQ motherboard is overheating or shutting down, it requires replacement.
A functional motherboard connects all of your hardware. If you notice a burning smell coming from the motherboard or if the motherboard is off completely, consider changing out your motherboard.
Cosa ti serve
To soften the adhesive holding the camera together, heat up the edges of the glass lens using a heated iOpener on the device. Alternatively, you can use a heat gun to loosen the adhesive.
Leave the Opener on the glass lens for two minutes.
