Introduzione
If your Nest Cam IQ has lost clear viability, you most likely have a cracked lens, which Requires replacement.
A functional lens provides a clear view. If you notice poor quality or lines when pulling up Nest Cam IQ recordings, consider changing out your lens.
Cosa ti serve
To soften the adhesive holding the camera together, heat up the edges of the glass lens using a heated iOpener on the device. Alternatively, you can use a heat gun to loosen the adhesive.
Leave the Opener on the glass lens for two minutes.
