Salta al contenuto principale
Nespresso Pixie Internal Diffuser Replacement
Cosa ti serve
  1. Nespresso Pixie Internal Diffuser Replacement, Internal Diffuser: passo 1, immagine 1 di 1
    • Unplug the machine from any outlets.
    • Remove the water tank by pressing the top button and pulling outwards.
    • Make sure there is no fluid left in any part of the machine.
  2. Nespresso Pixie Internal Diffuser Replacement: passo 2, immagine 1 di 2 Nespresso Pixie Internal Diffuser Replacement: passo 2, immagine 2 di 2
    • Use a Torx T5 screwdriver to detach the lever of the machine on both sides.
  3. Nespresso Pixie Internal Diffuser Replacement: passo 3, immagine 1 di 1
    • Remove the drip tray using your hand.
  4. Nespresso Pixie Internal Diffuser Replacement: passo 4, immagine 1 di 1
    • Use your hand to remove the black drip tray grill behind the drip tray.
  5. Nespresso Pixie Internal Diffuser Replacement: passo 5, immagine 1 di 2 Nespresso Pixie Internal Diffuser Replacement: passo 5, immagine 2 di 2
    • Use a Torx T4 screwdriver to unscrew each screw on the faceplates.
    • Remove the faceplate using a metal spudger.
    • Be sure to start in both corners to separate the pieces.
  6. Nespresso Pixie Internal Diffuser Replacement: passo 6, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Locate the two springs in each top right corner and use a set of tweezers to remove them.
    • Be sure to set the machine in an enclosed container when this is done so as to not to lose the springs.
  7. Nespresso Pixie Internal Diffuser Replacement: passo 7, immagine 1 di 1
    • Take off the white plastic bits using a metal spudger.
  8. Nespresso Pixie Internal Diffuser Replacement: passo 8, immagine 1 di 2 Nespresso Pixie Internal Diffuser Replacement: passo 8, immagine 2 di 2
    • Remove the clear plastic bits using a metal spudger.
    • Be sure to pull it out using the hole in which it is indented.
  9. Nespresso Pixie Internal Diffuser Replacement: passo 9, immagine 1 di 1
    • Use your hands to remove the cables that give power to the machine.
  10. Nespresso Pixie Internal Diffuser Replacement: passo 10, immagine 1 di 1
    • Use your hands to remove the water spout.
  11. Nespresso Pixie Internal Diffuser Replacement: passo 11, immagine 1 di 2 Nespresso Pixie Internal Diffuser Replacement: passo 11, immagine 2 di 2
    • Seperate both halves of the machine using both a spudger and your hands.
    • Once you have unclipped the side at the top, middle of the side and base. You can push with a screw driver through the hole on the reverse side to help remove the plastic side.
    • Be sure to take your time and start in the middle. Note that it is incredibly well secured.
  12. Nespresso Pixie Internal Diffuser Replacement: passo 12, immagine 1 di 1
    • Use your hands to pull out the first lever housing in the spot shown in the picture.
  13. Nespresso Pixie Internal Diffuser Replacement: passo 13, immagine 1 di 1
    • Pull the brewing mechanism apart from the remaining plastic barrier.
    • Once it is separated, pull off the other lever housing in the same way as was described in the previous step.
  14. Nespresso Pixie Internal Diffuser Replacement: passo 14, immagine 1 di 2 Nespresso Pixie Internal Diffuser Replacement: passo 14, immagine 2 di 2
    • Use a spudger to unclip the clips holding the black case in place.
    • Pull the brewing chamber outwards from the machine and then pull it downwards to detach it.
  15. Nespresso Pixie Internal Diffuser Replacement: passo 15, immagine 1 di 2 Nespresso Pixie Internal Diffuser Replacement: passo 15, immagine 2 di 2
    • Pry off the clips holding the inner white chamber in place in the machine.
  16. Nespresso Pixie Internal Diffuser Replacement: passo 16, immagine 1 di 1
    • Use a spudger to take off your diffuser plate.
    • Insert your new diffuser plate.
Conclusione
Drew
Membro da: 11/05/23
260 Reputazione
1 Guida realizzata
UMass Dartmouth, Team 2-2, Gulbrandsen Fall 2023 Membro di UMass Dartmouth, Team 2-2, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G2
4 Membri
13 Guide realizzate
1Commento della guida
I’m sorry but this tutorial should be removed. You’ll just going to broke parts by following that.
biorn - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 41
Ultimi 30 Giorni: 170
Tutti i Tempi: 3,860
