Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
There are some instances when the spring which allows a person to fire a Nerf crossbow breaks. One you have opened up the Nerf crossbow you will be able to tell whether or not the spring has broken. If in fact you are dealing with a broken swing then you are in luck since it can be replaced.
  1. There are 19 1.0 cm screws in total.
    • There are 19 1.0 cm screws in total.
  2. Separate each part of the Nerf crossbow.
    • Separate each part of the Nerf crossbow.
  3. Use the screwdriver and unscrew each screw one-by-one placing each screw on the magnetic mat to insure they do not get lost.
    • Use the screwdriver and unscrew each screw one-by-one placing each screw on the magnetic mat to insure they do not get lost.
  4. Take the broken spring off of the trigger.
    • Take the broken spring off of the trigger.
  5. Replace it with the new spring you bought at your local hardware store.
    • Replace it with the new spring you bought at your local hardware store.
  6. Now that the spring has been reattached to the trigger repeat step two.
    • Now that the spring has been reattached to the trigger repeat step two.
    • Finish by performing steps two and three in reverse order.
Conclusione
how do you get the arms/wings off without damaging the lock on clip?
Coventeena - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 17
Tutti i Tempi: 3,048
